Hard Core Wheeling Preperation
Well I just admitted defeat today and hauled the truck into a shop to figure out why the beast isn't starting.
I've started throwing things around in my shop getting ready for its arrival. I would like to know what everyone suggests for a truck for some HARD CORE wheeling.
I am putting a snorkle and smoke stacks on, because I messed up my old engine going into mud water about headlight deep. Smoke stacks are not only for looks but hopefully will keep the water out of the exhaust.
I already have these, they just arn't on, because well it doesn't run right now.
What more will I need besides:
37" Super Swamper TSL's
Snorkle
Smoke Stacks
Warn Winch
1 Ton Axles
FOR SOME HARD CORE WHEELIN!!!!!!!
Let me know your opinions, i'd prefer all truck mods not what to bring. Because I am well aware of what I should bring for self recovery and I really don't want another chain arguement.
Trucks mods, if i've left anything out. Let me know what you think!
Snorkle
Smoke Stacks
Warn Winch
1 Ton Axles
Define Hardcore. This is different to everyone.
This rig gonna see rocks? Sand? Mud?
Since you are running stacks and some snorkel thing, I can assume deep water.
Diffs and t-case vents will have to be raised. You wil also have to figure out how to keep the water out of the transmission.
I am in water crossings every weekend, and I tear my axles apart every third trip. Water is inside every time. I replace bearings more often than I buy shoes.
Maintenance is critical for vehicles that see this much water.
Well im glad i see winch on there....
GOOD recovery points, best if there welded to the frame.
You COULD use more gears but i think you will be OK for now. But if your goin to get lockers do gears also.
Welding isnt that hard, probably have some one do it for you for a hundred bucks or less really.
Roll bar? or cage? Got one?
Safety Restraints. Make sure its got factory seat belts at the least.
I fully agree with 75f350.
Preventive maintenance if crucial with mud and water.
Any time you get back from a day in the mud toss one of those water sprinklers that waves back and forth.... Put one under the truck, then after a few hours pull it out and move the truck, after it dries up some, grease everything. I just replaced all the ujoint on both shafts of my truck, i did them all with the greaseable u-joints, for that extra security.
In mud and water, keep things lubed is very important, along with changing fluids frequently.
Ill post up when i think of some other things.
Also see what the prices of spools and mini spools are running.
