Starter cranks when shifting to reverse
Old Oct 13, 2008 | 05:47 PM
luckyranger79's Avatar
luckyranger79
My boss has an 88 F150 with an automatic. When shifting into into reverse the starter cranks. Anyone seen this before or know what would cause it? Thanks for the info
Old Oct 13, 2008 | 06:23 PM
Lou Braun's Avatar
Lou Braun
This sounds like a wire chafing problem in the steering column. I would do a good visual check first.
If there are no obvious problems the next step is to take a wiring diagram and a multimeter to check to see where the starter voltage is coming from when in reverse.
Lou Braun
Old Oct 13, 2008 | 10:53 PM
gweeds's Avatar
gweeds
Yes, you definitely have a short in the steering column. I don't think I've ever heard of that happening like that though, pretty cool (in a strange sense....)
If it is indeed a chafing issue, replace the wires and wrap them in some of that plastic spiral warp or similar product to prevent against future problems.
Old Oct 14, 2008 | 07:10 AM
Lazy K's Avatar
Lazy K
I seem to remember a similar problem on here a while back. If I remember correctly the neutral safety switch and the reversing light switch are incorporated in one unit in the trans and if faulty, can feed power to engage the starter when shifting to reverse. Maybe some of the electrical experts can confirm this.
Old Oct 14, 2008 | 07:25 AM
subford's Avatar
subford
Does this only happen when turning the key to the start position?
Does this happen when he shifts into REV with the engine running?
Old Oct 15, 2008 | 08:15 PM
luckyranger79
We actually figured it out yesterday. Column was unlikely due to the fact that the only wires running up are for the signals, hazards, horn and cruise. Found the neutral safety switch harness melted. Must have chafed and then shorted out. Having trouble finding a good harness though because one connector is shot. gonna have to do some digging. Thanks for the help, much appreciated.
