Pedal Sealing
Old Oct 13, 2008 | 12:08 PM
51ford fan's Avatar
51ford fan
Pedal Sealing
What are you guys doing to seal out the weather at the floor boards where the stock clutch and brake pedals come through.
Old Oct 13, 2008 | 01:58 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I use the stock plates and seals. Are yours missing?
Old Oct 13, 2008 | 05:01 PM
51ford fan's Avatar
51ford fan
I just completed installing a Toyota Manual Steering box with an early 70's Chevy Van Column. Everything shifted up and to the right so I cut out new sheet metal and installed it minus any seals to see if everything was ok. When I took it apart the orginal "repo" seal I installed 4 years ago was half missing. I thought I would see if anyone had any better ideas on sealing the pedals.
Old Oct 13, 2008 | 06:42 PM
ALBUQ F-1's Avatar
ALBUQ F-1
My seals are pretty torn up too, from side-play in the pedals. If you have tight pivot bushings, they seem to work OK and last fairly long.
Old Oct 13, 2008 | 06:57 PM
Julies Cool F1's Avatar
Julies Cool F1
Hi Guys,
I just got a piece of sheet rubber and cut slots for the pedals and steering column. Youcan cut the slots all the way to the edge so you don't have to pull everything apart to slip it over. Then just sandwhich the rubber between the two (might be three) metal floor plates. You can add a little "Ru-glide" to keep the pedal from binding.
J!
