03 Navigator Air Suspension Issues
I was wondering if any on else has had this issue? The drivers side in a couple of inches lower than the passenger side and at times the suspension will work fine (stayed aired up) and the other it partially dumpes and I get the Check sus light.with the drivers side 3-4 inches lower than the passanger. I sparyed the drivers bag and lines cant find any leaks. But found a leak at the dryer thanks to the stealer leaving the bolts out on the window washer box and it resting on the compressor. From doing a search I couldnt find any poss answers, and just dont want to start replacing parts for no reason. Hope you guys have some suggestions that will help..
