A/C Compressor replacement - 01 Exp
Old Oct 11, 2008 | 06:43 PM
jaytuck's Avatar
jaytuck
Need to replace a/c compressor on my 01 Expedition EB with 5.4 liter engine. I purchased rebuilt unit from local auto parts store. Dove into project today and it appears I will need to remove engine fan assembly in order to physically get failed unit out (and get replacement unit installed). I checked Alldata Pro for step by step instructions but found nothing.
For anyone out there that has done this previously - some questions:
1. Is it possible to make switch without removing fan? Is it possible to drop unit out thru bottom after refig lines are disonnected?
2. If fan removal is required, does Ford have a special tool (that hopefully could be rented from auto parts store) to grasp/hold belt pulley so fan shaft can be removed from output of water pump?
Thanks in advance for responses.....
Old Oct 11, 2008 | 07:12 PM
cbradford's Avatar
cbradford
I think if you remove inner fenderwell you can remove that way thats how I did it on my 97, no need to remove fan
1996F150XL
May 27, 2014 06:16 PM
hackdog
May 21, 2014 07:23 PM
runstang22
2004 - 2008 F150
Aug 8, 2013 07:29 AM
SleeprLegend
13
Apr 22, 2011 08:43 PM
larry derouin
Apr 5, 2005 08:38 PM
