9'' build question
Old Oct 11, 2008 | 04:31 PM
v8xploder's Avatar
v8xploder
9'' build question
On the pinion retainer (which has two bearing races pressed into it) my "upper" or most forward bearing (closest to drive shaft) sits on top of my pinion shaft and does not allow me to get the nut on when I have it mocked up. Im trying to assemble the pinion side of the rear end. Do I need to press/drive it down before the pinion nut can be installed? Im new at this so take it easy on me
Old Oct 11, 2008 | 04:48 PM
v8xploder's Avatar
v8xploder
http://i75.photobucket.com/albums/i3...0/100_2108.jpg
heres a link to a picture of what im talking about
Old Oct 12, 2008 | 12:57 AM
85e150's Avatar
85e150
Are you working with a book or video or some other instruction?
https://www.ford-trucks.com/article/...ear_Setup.html
Maintenance instruction video: Differential Rebuilding by Paul Zank
Old Oct 12, 2008 | 07:53 AM
v8xploder's Avatar
v8xploder
The ford trucks link you posted was the one I was going off of. One guy has told me that he normally has to polish the shaft to get the bearing to slip on and off by hand...
