Im not sure if Ive got this in the right forum, but My 77 F150 4x4 that I put a 460 in a few years back has some serious starting issues. It has the factory Ford ignition maybe the modules bad Ive been told I should take the entire ignition out and replace it with an MSD or something like it. A couple years back it had to be jump started to fire, the battery was fully charged, turns out a wire at the bottom of the dist. was worn through and losing the spark, its doing the same thing but I cant find any bad wires. If it is the module box would it be better to replace the whole ignition Ive never done it before. I dont use this truck much I doubt I put any more than 500 miles on it this year. Its just my play toy and work horse around the farm.
If you decide to get a new distributor, consider our custom curved Duraspark Distributor built with our new Full Length Oil Impregnated Bronze Bushing. The full length bushing improves timing stability and spark scatter. If stock appearance is not an issue, take a look at our one piece D.U.I. Distributor. Whether you choose the Duraspark or the D.U.I., we curve each on a distributor machine based on your engine combination. Please see them at:
