Gauges 88
Old Oct 11, 2008 | 09:53 AM
05chop's Avatar
05chop
Gauges 88
Whats going on here? Bang on the dash volt meter goes to normal.Dual fuel tanks one reads correct other gauge goes to way past full till the tank almost empty then reads normal.Oil pressure always reads in the middle now its in the H range.Water temp gauge goes to hot at first light then check engine light goes on.Tach reads lower rpm ok then as you drive it returns to lower setting low rpm reading.All of this make me think its a bad ground in the wire harness to the dash? whats your input?
Old Oct 11, 2008 | 09:55 AM
05chop's Avatar
05chop
Oh speedo works great along with the lights and turn signals.
