Sponsored by: Real Truck
identifying lift help!!!!!
Old Oct 11, 2008 | 04:44 AM
AllAboutDaZ's Avatar
AllAboutDaZ
i purchased a 01 F250 v10 4x4 supercab long bed that was lifted and wasnt given any info on the lift.
Is there any way of me being able to find what size life and what brand life i have?? and tips on how i can find this information out?? what to look for? maybe some measurement i can make to find out what i have?? By the way the truck has 37" tires on 17inch wheels. Your help is much appreciated
Old Oct 11, 2008 | 08:53 AM
DCSpecial's Avatar
DCSpecial
Maybe post up a few pictures of the suspension.
What color is the trac bar bracket?
How many leafs are there in the front leaf packs?
As for height, on the passenger side of the front axle measure from the axle tube (right next to the spring perch) to the bottom of the frame rail (right by the bumpstop). Post up the measurement and I'll be able to tell you approx. how much lift you have.
Old Oct 11, 2008 | 12:35 PM
rusty350250's Avatar
rusty350250
ditto what DC said measurments will be the best way to tell. another guess is a 6 inch most people put 37's on a 6inch lift, 37's will fit a 4inch but will fill the wheel wells alot more. pictures will also help
Old Oct 11, 2008 | 01:54 PM
AllAboutDaZ
alright cool ill get this info for you
and post it on here see what you can help me with
thanks bro
Old Oct 11, 2008 | 09:46 PM
AllAboutDaZ
DCSpecial
here are the measurements and more details on the lift:
front:
-5 leafs
-Fox Shocks with reservoir
-Grey/dark grey track bar bracket
-right side measurement was 11" from where bump stop mounts to the leaf springs
- shock measurement from bolt hole to botl hole 24"
-Adjustable track bar
-dropped pitman arm
rear:
-5 leafs also
- Bilstein shock 5100
-Stock block (2" or so)
-Air bags (over load)
any help is much appreciated
Old Oct 11, 2008 | 09:58 PM
DCSpecial's Avatar
DCSpecial
With the 5 leaf pack and grey bracket I'd lean towards a 6.5" Pro Comp.
Do the hangers and shackles look stock?
Old Oct 11, 2008 | 10:02 PM
AllAboutDaZ
the front brackets are stock they say ford on them
the rears i am not sure how i can tell ?
Old Oct 11, 2008 | 10:07 PM
DCSpecial's Avatar
DCSpecial
Rear hanger and shackle are going to be stock, most likely.
If they were dropped down 3", they could be the Fabtechs.
W/O any pics, based on the description I think it's the Pro Comp 6.5".
Old Oct 11, 2008 | 10:10 PM
AllAboutDaZ
i will try and take some pics tomorrow for you see if we can figure this thing out. Thanks for all your info so far and if there is anything else i should look for let me know so i can make note of that thanks again
Old Oct 12, 2008 | 01:17 PM
Heavy_Metal's Avatar
Heavy_Metal
Can you see a white part # on the front leaves at all?
Old Oct 13, 2008 | 01:54 AM
AllAboutDaZ
i dont see anything
Old Oct 31, 2008 | 05:38 PM
AllAboutDaZ
leaf pack says 22410
Old Oct 31, 2008 | 05:46 PM
OnlyFords4Me's Avatar
OnlyFords4Me
22410 is definitely Pro Comp. I think DC is right on.
Old Oct 31, 2008 | 08:03 PM
Heavy_Metal
22410 is a 4" lift.
Old Oct 31, 2008 | 08:31 PM
OnlyFords4Me
That's right. It's a 6" on the Excursion. My bad.
