Sponsored by: Auxito
new guy intro and quick question
Old Oct 10, 2008 | 03:25 PM
EUA 08's Avatar
EUA 08
Well, real quick. My name is Dan, i live in charleston s.c and i just graduated from The Citadel last may. i leave for the criminal justice (police) academy next sunday and will most likely be joining the marine corps reserves when i get back from that in 12 weeks. My truck is a 2002 F150 7700 4x4 extended cab. only mod is that its got a dynomax dual kit on it. my other ford is a 94 mustang cobra that is bone stock and i will be tearing into that after all my training. fiance has a 2003 focus.
Now that that is out of the way, i know alot of guys run 285's on their 4x4 150s but i was wanting to do something a little different and was wondering if anyone was running 305/75/16s on their stock 150? im kinda thinking i might get a little bit of rubbing
Old Oct 10, 2008 | 04:44 PM
Bobby82490's Avatar
Bobby82490
Is 305/75 even a tire size? Or are you talking about 305/70s? If you crank your torsions you will fit them with a little bit of rubbing. Im fitting 285/75 on my stock 2wd, with very weak front springs.
Old Oct 10, 2008 | 04:51 PM
EUA 08's Avatar
EUA 08
yea they make the 305/75. i guess i will just stick with the 285. i drive the truck to much to have the tires rubbing
Old Oct 10, 2008 | 04:53 PM
bla1879's Avatar
bla1879
those are like 33s right? i have 315s and they rubbed at max rotation of steering wheel and max flex of the suspension so yours prolly will too but not much
Old Oct 10, 2008 | 05:17 PM
EUA 08's Avatar
EUA 08
yea they are the same as 33 12.50s
Old Oct 16, 2008 | 02:38 AM
barlieto's Avatar
barlieto
i have mickey tompson baja claws 33 12.50 i had to instal 2 inch wheel spacers in the front to keep them from rubbing
Old Oct 16, 2008 | 05:55 AM
96f150's Avatar
96f150
EUA, You have the 7700lb package. Don't forget that this also has a heavier duty front spring (torsion bar) weight than the standard F150 does. Your front end may be a bit higher than ours already.
Rich
Old Oct 16, 2008 | 07:30 AM
shorebird's Avatar
shorebird
Dan welcome to the FTE forums. You might try asking again in https://www.ford-trucks.com/forums/forum64/ Kitty I think that you may have inadvertently posted in the wrong forum.
Old Oct 16, 2008 | 02:16 PM
bla1879's Avatar
bla1879
barlito do those spacers make you rub anywhere else? on the front or back of the wheel wells? i have a 6 inch lift and 35s and 2 inch spacres cuz my tiers rubbed on the top of the spindle but i had to do a lot of trimming on the fenders to keep them from rubbing
Old Oct 16, 2008 | 08:20 PM
barlieto's Avatar
barlieto
no sir there is no rubbing what so ever did you get yours from 4 wheel parts its my understanding that they sell the best ones out there
