Sponsored by: Real Truck
Help with cab light bulb replacement...
Old Oct 10, 2008 | 06:24 AM
weyland426's Avatar
weyland426
Just noticed I've got a clearance light out on my 08...can anyone direct me to the procedure for changing? Thanks.
Old Oct 10, 2008 | 12:07 PM
akford351's Avatar
akford351
If they're like the 05-07s there should just be a phillips head screw holding the lens covers on.. unscrew, take off.
The bulb is a 192 I believe... I replaced all mine with LEDs.
Old Oct 10, 2008 | 12:23 PM
weyland426's Avatar
weyland426
To be honest, I never even got up there and looked...figured it took some tool I didn't have. Do they make these LED's that fit into the same factory socket?
Old Oct 10, 2008 | 02:04 PM
GregsSD's Avatar
GregsSD
The cablights have just one phillips screw that holds each lens on.
I just switched my bulbs to LED and used the WLED-AHP6 from High Power SMD WLED Car Bulb specs
They work great!!!
Old Oct 10, 2008 | 02:17 PM
bpounds's Avatar
bpounds
Sometimes the bulbs just rattle loose too. Open it up and check before you go buy a bulb.
Old Oct 10, 2008 | 08:32 PM
riggz's Avatar
riggz
They work great!!!
Got any pics of them at dusk and night?
Old Oct 13, 2008 | 12:12 AM
GregsSD's Avatar
GregsSD
The last bulb on the passenger side is a standard bulb,
All the others are the LED bulbs,
The 2 lenses on the passenger side are the stock amber ones and the other 3 are the Recon smoked lenses so you can see the difference.
These LEDs are the same brightness as the stock bulbs but they put out a cleaner looking light color and they won't burn out.
