Does the 09 really only gain 10 hp?
#31
The thing is that our perception of speed and power has changed between now and in 1995. While its probably true that we don't need more than 310 horses, the competition has em, which means we are behind, which could mean to many buyers that the Ford isn't as good of a truck. Also a 1995 f150 with a 351 Windsor; 210 horse 325 torque does 0-60 in 9.1, while the 08 150 with 300 365, does it in 8.8. Thats not much of an improvement and that is because when the power goes up, it seems the trucks base curb weight is too. GM 403, Dodge 390, Toyota 380 and Nissan 318. Ford 310. They can do better and I think that is why many people wish they could do better in the engine debt
#32
Very rarely is it the people who use there trucks everyday that complain about the hp...they already understand theres more to a truck than HP. You and I agree that 310 or whatever the number is going to be just fine and power the truck perfectly. I still find it funny...my 95 had 195 hp and it powered it while lifted on 35's just fine....but suddenly 300 hp isn't enough 13 years later...It probably has a correlation to the number of bad drivers on the road today...LOL
I want as much as I can get and I see nothing wrong with that. I like my truck to be fun to drive, not boring.
If you're in the how much power is enough crowd, why not argue for 100HP and 250ft/lbs. Geared low enough, it should be able to pull 11K. It won't be easy or fast, but how much power do we really need, right?
Mike
#33
#34
First gen Lightning was 240hp/340torque.
Mike
#35
I never did buy a Ford truck based on power numbers. I buy them because they hold up for me. Do what I ask off them. An get the job done. Tell you what if you think Dodge an Chevy have better trucks go ahead an buy them. I looked at this new 150 an I like it a lot. Sure its not perfect but what truck is. Yeh Im sure we would like better MPG an maybe in time will get it. But hey its a truck. Ill say it again the build quality on a Ford truck is second to none. Show me a Dodge or Chevy that will stand up like a Ford truck. Sorry to say they wont.
#36
With almost 6000 lbs of weight to haul in crewcab trim, and a transmission that's geared more for economy (tall ratios, wide spacing) than acceleration, no wonder 300hp feels weak. Also note that this 300 hp engine often dynos just a bit over 200hp at the wheels. The Hemi dynos 270 or so, and the Titan about the same. The Tundra I think is making over 300 at the rear wheels.
With the new transmission, acceleration and towing will be improved a bit. But in the end, we're stuck with a relatively weak engine that's not a mileage queen either.
#37
The F150 hasn't been a mileage queen because the 4R75s tall ratios combined with the truck's porky nature made it work way too hard to get all that mass going.
Both have been addressed in the '09. The '09 will be down on power, but it will match and surpass the class on just about every other front.
Still, it's a real shame the Boss 6.2 isn't at least optional, if nothing else it would quiet the HP junkies (which I count myself among) and make for a better impression on the media. It wouldn't matter if it was limited availability, just as long as it was available.
#39
This is exactly the case with my 06 Explorer. The 4.0 is an absolute dog. It gets no better mileage than the competition (Pathfinder, 4runner, etc.), and is much slower, and tows quite a bit less. The qualities that initally attracted me (and others) to this truck, such as quiet cabin, good steering feel, rigid frame, is wearing thin after only 2 years of ownership.
#40
I only partially agree with this. The problem is, with the high competitiveness of the current market, having a half-*** powertrain and expect things like "noise and vibration" or "creature comforts" to sell, is just not going to happen. The reason is the competition is also constantly improving these areas as well. The 04 F150 was quite a big ahead of Chevy and Dodge. But now that Dodge has a hydroformed frame and a good interior as well, and the Chevy just as refined as the F150, there's no real advantage on Ford's part any more.
On it's own the 5.4 is torquey and does well in front of the 6-speed, it's also a pretty smooth engine...especially as it revs. Relatively smooth revving has always been a positive trait of the Modulars.
The 4.0L is a rough, thirsty p.o.s. and I completely understand your lack of patience with it.
I've said it a million times, I'm not a fan of the 3V 5.4. I think they should have spent money upgrading the 5.4 4V instead and went for a home run instead of a double in 2004, but the 4.0L really doesn't compare favorably in any respect to any of the Modulars.
#42
I know this is OT but if you think the 4.0 is a dog in a truck, it outright sucks in a Mustang. After a test drive of a manual transmission one, I didnt buy due to that engine. The car screams out for a modern OHC V-6 base engine like in the upcoming Camaro and the new Challenger.
Back OT, three valve heads may breathe better in theory, but GM can get more bang for the buck with pushrods and two valve heads in V-8 engines.
Jim
Jim
#44
Put it like this, at 25" of water (most heads are flowed at 28") the 03 Cobra heads exceed 200 cfm by .300" while the 3V head never breaks 200 cfm, even at .600" lift and the factory 3V cams only offer .440" lift.
Those "Mustang gurus" need to check their facts and quit regurgitating old Ford press releases.
#45
Jim
Jim
In response to the last sentence, Modulars need multi-valve setups because of the smallish 3.552" bore. You'll never compete on valve area (and flow) when you have a 3.5" bore and the comptition has 4" if you stay with an inline wedge setup.
Another drawback to the 3V head, it has two 34mm intake valves versus two 37mm intake valves in the 4V heads and the valve and spark plug placement prevents you from going much bigger.
The 4V chamber will handle two 39mm intake valves.
