just completed my header install 74F100 390, went pretty good but had to jack the motor up for the passenger side. Used a block of wood but found out i had dented it a little(really not much at all) when i cranked it up there was a loud knocking sound. got back under the truck and seen the problem
Is there any way to pull the dent without pulling the oil pan?and did it hurt anything for the short time it was running
If you are sure the knock was internal, oil starvation is likely.
I'm not going down the gloom and doom path without more info. Did you happen to notice the oil pressure gauge? How many minutes, or even seconds was it running?
You might have dodged a bullet, but the only way to know is to start looking for blood. LOL Pull the dizzy and pre-lube the engine. It's an easy way to check for oil pressure without spinning the crank. I would be dropping the pan if oil starvation was a real possibility.
oil starvation isnt the problem it was running like a top when i started the header install and jacked the motor up yes i even used a block of wood but it still creased it some. i figure the crank must be tapping on the pan.wasnt even running 1 minute the crease in the pan is at the back near flywheel.. somebody out there must have done this before
The only place I can imagine using a block to lift the engine is under the sump(up front)on mine. I'm guessing you jacked it up then placed a block on the crossmember? let the engine down on it ? Suggestion, use a 4x4 across the fenders with a chain to (secure)suspend the engine. Towels on the fenders if you have one of those pretty trucks. Leaving the jack in place for assurance.
As to a dent at the rear of the pan, probably just have to live with it till you need a new gasket
You can repair a dented pan by welding a nut to the pan and scewing a bolt in and using this for a pulling anchor. The shallow part of a FE pan is very close to the crank , you should never jack the engine there.
yes the crease is in the shallow part, thought about lowering the pan some and using extra gaskets?I am concerned about the damage if any when the crank was tapping the pan?
If you didn't run the engine very long you shouldn't have a problem. If you are going to install an extra gasket you may as well pound out the crease in your oil pan. Then you won't need the extra gasket.
I'd think the crank is more than likely fine. I think Hotwrench has the best idea short of removing the pan. While most oilpans can hold the weight of the engine while sitting on the ground.... not many oilpans can hold the weight of the truck. I'd be concerned more with the pan possibly being hairline cracked besides being dented. Hopefully not the case but I'd keep a close eye on it for weeping. But if it's not cracked the welded nut and slide hammer just might do the trick!
Thanks for all the help, i will rent a slide hammer and try it with the nut.It finally stop raining so i went out with a straight edge and measured the crease 1/4" must only be a 1/8 clearance between crank and pan. cant wait to get her out with the headers installed(never will understand the stock manifold design)
If you don't want to rent a slide hammer just use a large link chain and bolt it to the pan then you can use a pry bar against the crossmember or axle and pry down-- thus pulling the dent. Years ago we installed a 390 in a pickup didn't know about the dented pan - this is how we fixed it.
The last ime I tried to weld an oil pan while it was still on the vehicle, it made me cry. Then I had to do the removal twice because the replacement was free if I dropped it myself. That chore wasn't quite as easy, it wasn't an old Ford truck.
If you decide to drop the pan, here is some food for thought:
Note: I J-B'd the thing on the pan. So far, so good.
