castor pinion angle.
Old Oct 9, 2008 | 04:34 PM
Henrys son's Avatar
Henrys son
Hi whats castor angle for 76 F250 with 44 low pinion.Whats the front pinion supposed to be 2" or 0".
Old Oct 16, 2008 | 03:18 PM
Henrys son's Avatar
Henrys son
Pinion angle for correct castor?????????????
Old Oct 16, 2008 | 09:51 PM
dlburch's Avatar
dlburch
Preferred caster is +3.5 degrees, the acceptable range is +2.75 to +4.25
Preferred camber is +1.5 degrees, the acceptable range is +1 to +2
Toe-in should be 1/16 to 1/4 inches (I tended to set them as close to 1/16in.)
..but caster is not the same as pinion angle...but definately dependent on each other on a solid axle
Old Oct 17, 2008 | 03:18 PM
Alvin in AZ's Avatar
Alvin in AZ
My '75 Shop manual sez toe-in is supposed to be 0 to 1/8".
I've experimented with toe-out an' all and decided "I like" 0 to 1/32".
YMMV
You got a ~flat ~level place and a good 1" wide tape measure? ;)
http://www.panix.com/~alvinj/file12/toe-in1.jpg
http://www.panix.com/~alvinj/file12/toe-in2.jpg
What I found taking mine to the dealer twice, is they won't bend an I beam.
If it's "within spec" they won't adjust the toe-in either.
Charge you for the work, but not even touch the bolts on the clamp.
Mechanics get paid on speed, not quality of work.
When you pay someone to do manual labor for you...
you are paying them to go as fast as they can. :)
Leave me out of it.
Both times they left the toe-in closer to 1/8" and front tire cupping was the
result. That's when I decided I could friggin do a better job than the "pro". :/
The main reason I can get away with it is... I have the twin-I-bean
suspension and it lends itself to a-do-it-yourself-er since toe-in is all the
dealership will adjust or "will ever have to" adjust on these rugged, simple
suspension systems.
And figured out how to make a set-up where I could get repeatable results
when measuring. As simple as that.
BTW, the "flashy" raised letters on a tire will screw my method -right up-,
right now. ;) ...never had that trouble on anything this ditch-digger ever
bought tho. ;)
Alvin in AZ
Old Oct 17, 2008 | 03:27 PM
Henrys son's Avatar
Henrys son
cOOL THANKS FOR ALL THE INFO.aNYONE WITH STANDARD HIGHBOY,CAN YOU MEASURE WHAT THE FRONT PINION ANGLE IS.mINE WAS SET PERFECTLY,BUT LIFT HAS ALTERED THINGS,SO I JUST NEED TO PUT DEGREED SHIM UNDER LEAF SPRING TO GET IT RIGHT.
347Flatty
Aug 25, 2025 11:05 PM
Melendez7.3
Apr 29, 2015 07:34 AM
dillinewton
Offroad & 4x4
31
Jun 16, 2014 09:05 PM
1978fordf250
Offroad & 4x4
Jan 2, 2007 09:48 PM
wileec
1978 - 1996 Big Bronco
Jul 9, 2004 09:15 PM
