Park Brake
Old Oct 9, 2008 | 02:03 PM
Rdh605's Avatar
Rdh605
Park Brake
OK, how do you adjust the park brakes on an '06 F150...haven't looked yet, thought I could get a hint here before I get home tonight
Old Oct 9, 2008 | 02:20 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
use it every time you park...sorry, couldn't help myself.
I believe there is a tension adjust along the frame-rail. but I have no idea honestly. I use my P-brake every time I park and have never had an issue
Old Oct 9, 2008 | 02:23 PM
Rdh605's Avatar
Rdh605
I use it on grades when i have a trailer hooked up
Old Oct 9, 2008 | 10:05 PM
silver05fx4's Avatar
silver05fx4
more than likey if you never uesd the parking brake till now it more then likey froze up and just needs clean and some lube
or could have a bad axle seal and the pad aren't just grabing
best thing you could do is take one side a part and look at it and go from their
Old Oct 10, 2008 | 06:23 AM
Rdh605's Avatar
Rdh605
The brake works...it just isn't holding very well
Old Oct 10, 2008 | 07:25 AM
SteveVFX4's Avatar
SteveVFX4
I'm pretty sure there is a small gear sprocket/wheel on the back side of the brake drum that is used for adjusting the e-brake. Should be a little notch cut out on the back side of drum to access that sprocket. You'll probably have to pull your driver's rear wheel off. Probably one on the rear passenger side too.
The rear brakes are combination of disc and drum with the e-brake being a drum brake inside the rotor.
