gauge install
Old Oct 9, 2008 | 12:22 PM
dieselsmoker's Avatar
dieselsmoker
gauge install
im just wonder when i go to install my gauges and disconnect the batteries should i put my truck back to the stock setting or can i leave my tow tune in the truck
Old Oct 9, 2008 | 12:26 PM
jmaskew's Avatar
jmaskew
What kind of gauges are you installing? I didn't disconnect the batteries when I installed mine.
Old Oct 9, 2008 | 02:00 PM
dieselsmoker
im installing pre turbo pyro, trans temp
Old Oct 9, 2008 | 04:58 PM
riggz's Avatar
riggz
No you don't have to disconnect the batteries or detune it. The gauges should be hooked up to an ignition switched power source so if the key is off, no power should be flowing. They also do not read anything from the computer so no need to detune it.
