check engine light.
Old Oct 9, 2008 | 12:06 PM
gearhead351's Avatar
gearhead351
check engine light.
Hey all. I got a question...
My buddy had a 1990 Ford F350 460 5 speed. It has a check engine light that pops on and off every now and again. It seems to only come on once the truck is hot, no unusual pattern......
how might I pull the code on it? Obviously a code scanner but where do you connect it? Thanks in advance . I've worked on ford trucks for years so I am very mechanically inclined but pulling a code is way easier than searching for days to find the issue.
Old Oct 9, 2008 | 12:24 PM
subford's Avatar
subford
Sounds like the EGR valve but can hook the code reader up near the air filter box on the LH fender apron.
To check your codes go to one of these links below:
This is good for the KOEO test:
Ford Fuel Injection How To Run a Self-Test
This one is good for the KOER test:
Ford Computer Codes
Old Oct 9, 2008 | 09:23 PM
Dustin1690's Avatar
Dustin1690
Yeah Im almost 100% sure its the EGR valve sticking same problem happened to someone I know and got the codes read and thats what it was EGR valve sticking get unstuck or you have to replace it
Old Oct 10, 2008 | 09:57 AM
rattosh51's Avatar
rattosh51
Replace it, you'll be better off.
Old Oct 10, 2008 | 10:01 AM
Conanski's Avatar
Conanski
Don't guess.. pull the codes first!!
Old Oct 11, 2008 | 05:49 PM
gearhead351
hey guys I found the problem! pulled the codes at autozone with a scanner and it turns out it was code 119- Low VAT sensor voltage. Changed sensor old one was covered with oil. New one; Runs awesome . The VAT from what I understand measures the incoming air temp, and adjusts fuel mixtures to suit it. Thanks for all the help guys!
