Hard switch to OD
Old Oct 9, 2008 | 08:57 AM
dpellicone's Avatar
dpellicone
Hard switch to OD
My 1985 F150/5.0Fi, automatic has been changing into OD with a hard thud. Also i have noticed that the tranny takes a bit to switch gears and has a hard time "deciding" on what gear to be in at mid range speeds 30-40 mph. Had the tranny serviced not too long ago. fluid was fine and no signs of wear. Can this be a rear end or drivetrain issue or has the tranny finally gave up
Old Oct 9, 2008 | 01:24 PM
Franklin2's Avatar
Franklin2
I would check the throttle cable adjustment that goes to the tranny.
