screeching for vengeance
Old Oct 8, 2008 | 10:17 PM
82_F100_300Six's Avatar
82_F100_300Six
man I had a belt (82 F100...) screeching before I rebuilt the motor. When I got everything back together it was still screeching (like 15 seconds after each startup). So I loosened the alternator and cranked it up, sure enough it is the alternator, not the power steering. the belt looked a little hard so I pulled another out of my garage that fit, and it worked but would screech for about 5 seconds at startup, then it got bad like the other one, so I was back to where I started. Today I bought a NEW belt and I heard it screech for a couple seconds one time in about six startups, and I'm thinking this:
-the new belt is on its way to meeting the fate of the other belts, ie maybe I need to clean the alternator pulley.
anybody got tips on belts..not the serpentine kind?
thanks
Old Oct 8, 2008 | 10:21 PM
85e150's Avatar
85e150
Feel your alternator after it runs for a few min. Mine was so hot after a couple of min. you couldn't touch it. This has happened twice, so if it is the alternator, buy the better rebuild vs. the "1 yr" warranty job.
If it is the belt, try some belt dressing.
Old Oct 9, 2008 | 07:08 AM
srercrcr's Avatar
srercrcr
I've read belt dressing is a short term solution, but will later make things worse.....foreign material on the belt/pulley makes it slip.
Old Oct 9, 2008 | 09:17 AM
Sycostang67's Avatar
Sycostang67
Some WD-40 will keep it quiet. I would check your alt. if it's getting hard to spin and causing your belt to slip it wont be long before it seizes. Are you tightening the belt by yourself, perhaps having someone there to help would allow you to tighten in further.
Seriously though, if you have multiple belts and one is squealing, just a little shot of WD-40 will eliminate it long enough to let you identify the bad one without removing them all. It will evaporate/burn off quickly.
Old Oct 9, 2008 | 09:46 AM
82_F100_300Six
well if it gets too bad, I'll just get rid of the belt driven alternator and install and electric one.
Old Oct 9, 2008 | 01:57 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
If the pully is really smooth, you can roughen it up with some sand paper to help remove the "glaze".
Old Oct 10, 2008 | 03:35 PM
bob_351's Avatar
bob_351
[quote=82_F100_300Six;6630775]well if it gets too bad, I'll just get rid of the belt driven alternator and install and electric one.
umm do you understand what an alternator is?
edit: sorry i just saw your little smiley way down there :P
Old Oct 10, 2008 | 03:43 PM
Rockstone's Avatar
Rockstone
[QUOTE=bob_351;6635417]
Yeah, he got me on that one too.
