Starting issues
Old Oct 7, 2008 | 09:12 PM
Core250PSD's Avatar
Core250PSD
Starting issues
So about 2 months ago my truck started making a terrible almost grinding noise when I tried starting it, and it won't crank over when it does this. I turn the ignition a couple times it makes the noise and eventually it starts up. I then dropped the pennies and got a new starter for it, and installed it. Same problems. I doesn't do it every time, but it's becoming more frequent. Whats the gear the starter engages on? I think the teeth are stripped and the starter is just grinding on that. I failed to check it out when I put in the starter. It's the only thing I can think of that would cause this. Unless anyone else has any ideas.
Old Oct 7, 2008 | 09:13 PM
Core250PSD's Avatar
Core250PSD
oh, I forgot to mention. It's got the E4OD tranny.
Old Oct 7, 2008 | 10:53 PM
Core250PSD's Avatar
Core250PSD
Nobody has any ideas?
Old Oct 7, 2008 | 11:24 PM
AndysFords's Avatar
AndysFords
My 88 does that occasionally, I would say flywheel ring gear. Are you sure the starter is on right, the bolts aren't loose, they are in the right hole? Sometimes these starters may go on with all the holes rotated around one, then its not aligned right.
Old Oct 8, 2008 | 01:22 AM
884x4broncoII's Avatar
884x4broncoII
i would second the flywheel ring gear, id try pulling the starter and taking a look to see if you see anything out of the ordinary
Old Oct 8, 2008 | 06:33 AM
Core250PSD's Avatar
Core250PSD
Well I'm gonna pull the starter today to checkout the flywheel ring gear. And then I'll see if the starter is on correctly. I just thought you unbolt the old, and bolt up the new. How much will a new ring gear cost, and how hard will it be to replace?
Old Oct 9, 2008 | 12:08 AM
Core250PSD's Avatar
Core250PSD
Well I put my Destination M/T's on today and while I was at it, I tore the starter off, and looked at the flywheel ring gear and it's all chewed up. Anyone know of an inexpensive, or cheaper place to find one? And what is intaled in installing it? I'm gonna have to drop the tranny aren't I?
Old Oct 9, 2008 | 12:23 AM
884x4broncoII
it shouldent cost to much unless you have it done at a shop the transmission will have to come out.
Old Oct 9, 2008 | 02:42 PM
Core250PSD's Avatar
Core250PSD
any write ups of this procedure? I tried a search and nothing
Old Oct 9, 2008 | 09:20 PM
Core250PSD's Avatar
Core250PSD
so I called the tranny guy today and he quoted me $400 labor, and the price of the flexplate tacked on top of that. I don't don't think i have the facilities to accomplish the task at my house. Sound reasonable?
Old Oct 10, 2008 | 06:50 AM
Hussler's Avatar
Hussler
I'd go that route. I paid $400 a few years ago for my F250 460 5 Speed, same issue. I'm not sure how that ring is attached .. pressed on I guess.
