No brights
Old Oct 7, 2008 | 02:36 PM
rattosh51's Avatar
rattosh51
No brights
When trying to turn on my hi-beams the other day on my 94 F150 4x4 5.0, the blue indicator came on, but no brights.
They had worked the day/week before, so am assuming the bulbs are ok. Is the switch located in the signal/wiper/hi-beam stalk, and do you have to replace the entire thing? Am going to check the bulbs, but am pretty sure they're fine.
Old Oct 7, 2008 | 03:11 PM
subford's Avatar
subford
Yes that is where the switch is located.
Yes if you replace it, it is the entire thing.
Reading a post the other day where a guy said he took his apart and sanded the contacts and re-greased it.
Said it worked great after that.
I have one in my hand and the screws look like five small torx screws.
Old Oct 8, 2008 | 10:01 AM
rattosh51's Avatar
rattosh51
thanks Bill...I'll try the sand & regrease procedure 1st and see if it works.
Old Oct 8, 2008 | 10:29 PM
White Max's Avatar
White Max
If you do end up replacing it, it's called the Multi-Function Switch, or MFS. It's a pretty common failure on Fords of this vintage.
-Rod
Old Oct 9, 2008 | 07:47 PM
donnor's Avatar
donnor
wiper/dimmer switch rebuild
Yes, these can often times be "rebuilt". Just be careful when you disassemble the unit. There are several small parts, including a couple of springs and contact plates. Be sure to take note of the placement & orientation of these pieces in order to assure proper reassembly. A digital camera can perhaps be your most important tool on a job like this.
Redimpling of the contact points (using a small punch from behind) can restore adequate pressure to reduce the resistance that leads to overheating and melting of the plastic components of the switch assembly. Liberally apply a good quality dielectric grease to all contacts prior to reassembly.
New MFS's can be purchased at any reputable parts stores; but hey, where's the fun in that?
dn.
