Sponsored by: Real Truck
tire size
Old Oct 7, 2008 | 08:11 AM
willy_scott2000's Avatar
willy_scott2000
tire size
I have stock wheels on my f-350 sd dually v8 5.4 gas not diesel.
question: what is largest size tires I can put on wheels?
Old Oct 7, 2008 | 10:08 AM
brian42's Avatar
brian42
Veteran: Navy
What year is your truck?
Old Oct 7, 2008 | 12:39 PM
Supercab's Avatar
Supercab
Wink
Why does everyone want to install larger tires???? unless you have a 4X4 and the need to go off roading then leave the stock size on your truck it will handle much better!!
Old Oct 7, 2008 | 01:57 PM
Heavy_Metal's Avatar
Heavy_Metal
I disagree.
The stock 265's that came on my truck provided near zero traction in wet or gravel conditions causing skidding while turning on DC surface streets and heavily traveled highways. Accelerating was an issue also in the same or lesser conditions. While I believe going to a 35" tire is overkill for the street, a larger (marginally taller/wider) tire can be beneficial to any rig.
Old Oct 7, 2008 | 02:02 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
You could get a 1-ton dually with a 5.4????
Old Oct 7, 2008 | 02:24 PM
78bigbronco's Avatar
78bigbronco
Well I wont necessarily argue against that but I wouldnt be exclaiming that without even knowing what willy_scott's intentions are... maybe he is building a show truck? Maybe he is going off roading? Perhaps he should have given us some more info.
And as far as I am aware the 5.4 has always been the standard motor on a 1 ton with duals.
But to properly answer the question we need some more info on the truck like model year, and what wheels it came with.
Old Oct 7, 2008 | 04:17 PM
willy_scott2000
tire size
i have stock rims on my 1999 f-350. gas not diesel v-8 265's tires. like to go a tire maybe a little bigger. I live on a farm and even in 4x4 it still spins with all tires sometimes. need mud tires
Old Oct 7, 2008 | 08:01 PM
DCSpecial's Avatar
DCSpecial
FWIW, if you go over a 255mm width you'll want to install a spacer between the rear duals to prevent them from rubbing together under heavy load.
Old Oct 8, 2008 | 12:14 PM
brian42's Avatar
brian42
Veteran: Navy
I'm not sure what the duals come with, but mine are 16x7. I have the optional 265 tires on them and am happy. I've heard of people going as high as 315's on the stock 7" wide rim. They will fit on the rim, but you will notice (very soon) that you will wear down the center of the tread very fast as you have curved the tire to fit it onto such a narrow rim. Many tire websites have recommended tire widths for rim sizes. I can't remember off the top of my head but I think Procomp is one of them. If I go any wider (I'm thinking my next set is going to be 285/75/16) then I will buy a new set of wheels that are around 8" wide to get the best traction and maximum life out of them.
Old Oct 8, 2008 | 01:04 PM
DCSpecial's Avatar
DCSpecial
DRW have 16x6
Bud Mud
May 23, 2014 07:40 AM
quincyj34
Mar 5, 2014 11:30 AM
liftedsupercrew
2004 - 2008 F150
Feb 19, 2010 03:11 PM
95-F250
Oct 10, 2006 08:37 PM
