2006 Expy XLT electrical problems??
Old Oct 7, 2008 | 07:14 AM
60_cent's Avatar
60_cent
She broke down Friday and was towed to the dealer. The dealer stated that the #32 fuse in the fuse box on the passenger side panel blew. The trace what they could however could not find a problem.
I picked the vehicle up and drove it 20 miles before the fuse blew again. When it blows the check engine light comes on, the O/D flashes and a wrech light comes on. The vehicle will run rough cut off at a light.
WTF is going on. I towed it back to the dealer and they are still looking at it.
I have 74k on the vehicle and owned it since knew. The only major work I had done so far is replacing the torque converter at 60 k because a mechanic added to much fluid into the trans during a routine service.
Old Oct 7, 2008 | 09:00 AM
alloro's Avatar
alloro
According to your fuse index, what does the #32 fuse give power to?
Old Oct 7, 2008 | 10:15 AM
60_cent's Avatar
60_cent
I'm not sure...
The service advisor stated that the tech told her it controlled the o2 and mass air flow...
Old Oct 7, 2008 | 01:42 PM
alloro's Avatar
alloro
In that case it's probably a cracked heater coil in one of the O2 sensors and is shorting to ground as it is bounced around.
