wanting to port
Old Oct 6, 2008 | 09:02 PM
bigblueovalman's Avatar
bigblueovalman
wanting to port
I have a set of E7TE heads that are completely rebuild from Allied Motorsports.They do great work. The're going on my 351 HO along with some more goodies. I want to grind out the smog bump and do some blending in the port to help the flow so I want to remove the valve so I don't nick the stem and get up under the seat. Question: These heads have the posilock seals on the valves and wondering if they can be reused after removing them. Do you need a special tool to remove and reinstall or what? I have done some porting and polishing but have only used the old umbrella seals. Thanks for your advise. Bud
Old Oct 7, 2008 | 07:56 AM
Conanski's Avatar
Conanski
Yes, I bet you'll find you can remove the valve without removing the seal.
