Greasing the upper ball joint
Old Oct 6, 2008 | 08:41 PM
Jaaaaaaackman's Avatar
Jaaaaaaackman
What kinda of grease gun fitting can grease the upper ball joint on a Dana 60? And where does one buy this fitting?
Thanks jack
Old Oct 7, 2008 | 01:01 AM
kawa's Avatar
kawa
I think that it is called a "Right Angle Grease Coupler" Harbor Freight has them but you have to order them on line, #3495-OVGA. They run around $4-$5.00.
Rog
Old Oct 7, 2008 | 01:32 AM
kawa's Avatar
kawa
Here it is.
Rog
<center> RIGHT ANGLE GREASE COUPLER <!-- PHOTO --> <table border="0"> <tbody><tr> <td> </td> </tr> </tbody></table>
</center>
Reach out-of-the-way zerk fittings such as those on ball joints. Coupler fits standard grease guns. Poly seal fits snugly to zerk fitting.
1-5/8'' long, 1/8'' NPT
<!-- BEGIN MODEL NUMBER --> <!-- END MODEL NUMBER -->
ITEM 3495-0VGA
Old Oct 7, 2008 | 06:48 AM
Jaaaaaaackman
Kawa Thanks,,,,,,,, I called NAPA and cross refranced and they have the same thing part#700-2020....... Very Cool will get my coupling today,.........Thanks again
Old Oct 7, 2008 | 08:05 AM
Cuda_jim's Avatar
Cuda_jim
I think you would be better off replacing the straight zerk fitting with a 90 degree one.
I haven't had much luck using the adapter above. It seems to spew grease everywhere except into the fitting.
Maybe I have a cheap one. I actually I have 3 like that and none work.
Could be operator error too
Maybe this one would work but it's $60
http://www.thefind.com/garden/info-zerk-fittings
Old Oct 7, 2008 | 11:21 AM
Jaaaaaaackman
CudaJim , I put the ball joints in last year and tried to put 90 degree zerks in but they were too close to the axle shafts, not enough room they hit,,,,, maybe I had the wrong zerks......
Old Oct 8, 2008 | 06:45 AM
Cuda_jim's Avatar
Cuda_jim
Yep, you need a low profile zerk. I had some on the shelf but can't tell ya where they came from .
You might get lucky and find them at a tractor supply store. You don't need much to clear the u-joint.
Mine looks very close but after many years I haven't see one get knocked
off. I see how it Could happen if I did a lot of off-road, mud playing.
Before I found the 90 fitting I have I would just remove the flat plug and install a 90,
grease and re-install the plug. It only took a couple more minutes per side.
Old Oct 8, 2008 | 12:00 PM
kawa's Avatar
kawa
Zerk fittings - Shop sales, stores & prices at TheFind.com[/quote]
The above fitting grease attachment requites you to replace the Zerk with a different style of grease fitting as well. They do look kind of cool. I wonder if they get plugged as often as the normal Zerk?
Rog
Old Oct 8, 2008 | 02:38 PM
Talyn's Avatar
Talyn
Yea, I noticed the stupidity of the strait zerts they stick in there sometimes.
You should be able to find a competent 45 or 90 to fit in there and keep the u-joint from hitting.
Supercab
1983 - 2012 Ranger & B-Series
Feb 10, 2017 06:52 PM
4.9LOldFordTruck
Jan 20, 2016 04:38 PM
FordTruckChuck
1997 - 2003 F150
Oct 27, 2015 04:01 PM
holyspirit
Jun 3, 2015 10:45 AM
Tlattin
Dec 29, 2003 09:44 PM
