tire probs
Old Oct 6, 2008 | 08:37 PM
carter442's Avatar
carter442
tire probs
im puttin 33 inch tires on my sock 86 how d i correct the problems of my tires rubbing against my frame?
Old Oct 6, 2008 | 09:59 PM
Dodge/Cummins's Avatar
Dodge/Cummins
You could use wheels with more backspacing.
This puts more stress on the wheel bearings but people do it all of the time.
Old Oct 6, 2008 | 11:44 PM
Dave Sponaugle's Avatar
Dave Sponaugle
I am running 33" tires, 285/85-16 mud tires on my 86 4x4.
No rubbing at all.
Old Oct 7, 2008 | 12:06 AM
Blueovals&Blacksmoke's Avatar
stock for the fords of the 80-86 use about a 32 inch tire
Old Oct 7, 2008 | 01:10 AM
Dodge/Cummins
No rubbing at all.
Are you sure they are only 33", I run 255/85R16s on my Dodge and three different manufacturers tires have been 33-34"
I've never ran 285s but I'd think they out to be 35" or so tall.
I'm guessing carter442's 33" tires are wider (33-12.5?) which would explain the rub. The 85 A.R. tires we're running are pretty narrow.
Old Oct 7, 2008 | 06:10 PM
symonds86's Avatar
symonds86
i have to run a bigger offset to fit my 315 75 16. you can convert your metic tires to inches here Metric To Inches Tire Size Conversion
Old Oct 7, 2008 | 06:15 PM
Dave Sponaugle
255 /25.4 = 10.03" wide at the tread.
10.03 * .85 = 8.52" from rim to tread.
So 8.52 + 8.52 + 16 = 33.04" tall
Old Oct 7, 2008 | 10:03 PM
Dodge/Cummins
Have you ever actually measured them?
I've found actual tire size to vary a lot from what it's supposed to be.
Anyway, my 255s have always actually measured slightly over33" up to 34"
No big deal, just my experience.
Old Oct 8, 2008 | 08:32 PM
Dave Sponaugle
Depends mostly on the tread pattern.
Mud tires usually run taller, straight treads are usually the shortest and all terrains fall in the middle.
When I buy a set of tires, if the dealer has 8 or 10 tires, I try to get a matched set.
And yes, same manufacturer, same product line, same size tire, I have seen almost an inch difference in tire height.
Quality control is nothing like it used to be.
Old Oct 9, 2008 | 06:12 AM
Dodge/Cummins
I can't believe they would let the tires get that out of spec., that's terrible!
I've noticed the same "size" tires will be a lot different from manufacturer to manufacturer but an inch difference from tire-to-tire is rediculous.
I don't think I'll measure every tire of a set or I might get PO'd!
I've always ran mud tires until recently and your right, they do tend to run larger in diameter.
I think they run the same "carcass" for the same family of tires and just "add" the tread to it and since the tread is deeper on mud tires obviously they would be larger in diameter.
Old Oct 9, 2008 | 10:41 PM
Dave Sponaugle
Since I have limited slip in both ends, I try to match mine as close as possible.
And so far I have not had any store give me a bad time about wanting to compare tires and pick the closest match tires if they have a couple extras in stock.
I guess dropping 8 or 9 hundred for a set of tires makes them willing to try and make me happy.
I just say, hey I have limited slip in both axles, I want a matched set of tires.
We line up 8 or so tires, and I pick the 4 closest ones.
Old Oct 10, 2008 | 01:52 AM
Dodge/Cummins
I would expect NOT to be able to find a "measurable" difference between a set of tires. As I said I've always assumed they would be closer than that.
If I knew someone around here that "shaved" tires I would have it done.
I guess you don't want them all shaved to match in diameter, you might end up with one that's virtually bald.
