i pulled my 4.2 engine to rebuild it and when disconnecting the wiring connections i broke the end off this sensor. it is aluminum i believe on the right side of the engine block threaded into what seems to be a bolt that is tapped into the water jacket. i would guess it is a coolant temp sensor but i'm not sure so if anybody knows for sure what it is please post back and let me know so i can get it replaced...thanks
