4x4
Old Oct 6, 2008 | 06:28 PM
JOHNNYRICH10's Avatar
JOHNNYRICH10
4x4
HEY GUY'S I HAVE AN 01 CREW CAB 4X4. I HAVE ONLY HAD IT A COUPLE OF MONTHS. I TOOK IT OFF ROAD YESTERDAY. dO I HAVE TO MANUALLY LOCK THE HUBS EVERYTIME I WANT TO USE MY 4X4. AND DO I NEED TO UNLOCK THE HUBS WHEN IM DONE? DOES IT HURT TO DRIVE WITH THEM LOCKED
THANKS,
Old Oct 6, 2008 | 06:35 PM
zx250's Avatar
zx250
Of the next Riffraff East
What markings are on your hubs? If they are stock, then they should have an auto/lock selector. The ESOF system is prone to troubles, air leaks being the most common. The hubs work off of a vacuum system the if any of the vac. lines leak, the hubs will not automaticly pull in. Many of use have switched out the OEM for aftermarket like Warn or others.
Old Oct 6, 2008 | 07:21 PM
rebelchevy02's Avatar
rebelchevy02
Theres only IMO a few things you can hurt by leaving your hubs in. 1 Fuel mileage, 2 Inner axle seals, at the differential. Now with your fuel mileage may not notice too much a change, not all do, and the inner axle seals usually are getting close to rotted by this day in age anyways, so its not like your going to cause major damage. The truck was meant to be able to drive in 4wd, its not like its a sin. These are just the wear items.
