35x12.5x15 Wheels
Old Oct 6, 2008 | 11:01 AM
Redneck1465's Avatar
Redneck1465
35x12.5x15 Wheels
I have a spare set of 15x8 in rims at the house and I was wondering if these tires would fit on these rims and fit under my 85 F150? Any ideas?
Old Oct 6, 2008 | 11:07 AM
nflfreak43's Avatar
nflfreak43
no. unless you have a lift on your truck and for a set of 35 in. tires you probably need a 4-6 in. lift. but the tires should fit on those wheels. (i think?) im pretty sure they will.
Old Oct 6, 2008 | 11:18 AM
85e150's Avatar
85e150
Tires will work on those wheels, but they won't fit under a stock F150.
Dick Cepek Tires&Wheels
Go there and look for 'tire fitment' in the list across the bottom.
8" lift required, so they say.
Old Oct 6, 2008 | 11:39 AM
nflfreak43's Avatar
nflfreak43
yeh u wont need no 8 in. lift 4 in. should do but some people go with like a 4 in. suspension lift and a 2 in. body lift and it looks real good
Old Oct 6, 2008 | 11:47 AM
Redneck1465
Well that stinks they were really cheap and almost brand new.
Old Oct 6, 2008 | 11:48 AM
nflfreak43's Avatar
nflfreak43
cheap aint always the way to go.
Old Oct 6, 2008 | 11:52 AM
nflfreak43's Avatar
nflfreak43
that is true i dont like body lifts functionality.
Old Oct 6, 2008 | 07:31 PM
Redneck1465
That might actually be a good idea because I already am pullin all the body parts off to do body work.
Old Oct 7, 2008 | 05:30 PM
kenworthfan's Avatar
kenworthfan
I have 4" of lift on my 1986 F150, and I was at the junkyard and found a decent set of 35s with chrome rims for 20 dollars a piece and I bought them, and they fit perfectly underneath my truck, but it has a 4" lift. As for the body lift, I personally arent a big fan of them at all, I would either buy the tires and do the lift the right way, or I wouldnt mess with it at all. Thats just my opinion.
Blake
Old Oct 7, 2008 | 07:23 PM
Redneck1465
Its only two wheel drive so it really isnt worth doing the lift kit to it. If I do it it will only be a body lift.
Old Oct 7, 2008 | 07:59 PM
kenworthfan
OHHH!! I, like UTfball68 just assumed it was a 4x4, there is not a chance they will fit with no lift, and you will probably be lucky to fit them with a 3" body lift on a 2wd. If they fit it would be a tight fit.
Blake
PS. I saw you were from IN too, what area are you in?
Old Oct 8, 2008 | 09:37 AM
Sycostang67's Avatar
Sycostang67
I had an 81 bronco with 35" mud kings and no lift. Those tires chewed on the fenders every time I hit a bump.
Being 2wd, I'd stick with 31's. You might get away with 32's and minimal rubbing if you use a stock type wheel.
Old Oct 8, 2008 | 09:59 AM
Redneck1465
Northwest Indiana.
Old Oct 8, 2008 | 11:16 AM
jason85351's Avatar
jason85351
i fit 35's under my stock 85 f150 4x4 they only rubbed when i turn to sharp but now i dont have to worry gotts 8 inch lift
Old Oct 8, 2008 | 08:17 PM
kenworthfan
Haha, were almost neighbors then. I live in northwestern Indiana also. Im in Wheatfield, right next to Demotte.
Blake
