the voltinator.
Old Oct 6, 2008 | 10:47 AM
DieselRunner's Avatar
DieselRunner
Exclamation the voltinator.
alright, so problem with daily driver.
so to start truck up this morning(I usually cycle the glowplugs a few times because sometimes they dont work sometimes they do). anyways, they cycle the second time around, so i go turn the key off and on but nothing this time. (now this could have happend when i turned the key to turn it over or just to cycle the plugs, i dont remember. anyways, truck has electricity so assesories, and has 12.5 volts from battery terminals. but as soon as the key, turns to the on position, big voltage drop, not total loss but dome light dims to just a faint glow and nothing happens.
i hope someone can help and i hope its a relativly easy fix cause i depend on this vehical to get to school and im broke. thank you. oh and the truck ran pretty good yesterday.
Old Oct 6, 2008 | 11:59 AM
tbone91's Avatar
tbone91
Check the positive battery cable at the passenger side terminal. Does the insulation look like it has been hot and/or is it swollen or cracked? If so, the cable may be corroded inside.
Just a wild first guess.
Old Oct 6, 2008 | 12:02 PM
Lazy K's Avatar
Lazy K
And remove the wire connections at the batteries. Clean the battery posts and the wire connectors, replace making sure they are tight.
Old Oct 6, 2008 | 03:02 PM
DieselRunner
yeah i didnt think to clean them since on first look they didnt seem any worse than usual. But sure enough after a slight cleaning, it fired right up beter then it has in a while!.
little embarasing but i got to school anyway.
thanks for the quick replys!
Highmark18
Nov 8, 2012 05:24 AM
strokerspeed
50
Sep 16, 2011 07:39 PM
98SurplusExpy
Mar 6, 2010 02:45 PM
gb'sfx4
Nov 17, 2008 07:12 PM
