Radio problems
Old Oct 6, 2008 | 08:49 AM
rg4's Avatar
rg4
Radio problems
In a drunken stupor, i accidently hooked up my jumper cables the wrong way while trying to jump start my truck. Fortunately, i was able to get the truck started and it seems to be running fine for now....except the radio no longer works. It doesn't turn on at all. Anyone know exactly what I should be looking for and what I'll probably need to do to fix the problem? Thanks
Old Oct 6, 2008 | 09:29 AM
texans's Avatar
texans
I would check fuses first. There should be one on the back of the radio, and one in the fuse box for it.
Old Oct 6, 2008 | 09:30 AM
texans's Avatar
texans
oh and welcome to FTE, you have join the best site for info on your truck.
Old Oct 6, 2008 | 09:46 AM
rg4's Avatar
rg4
Thanks for the welcome. The fuse was the first thing I checked for, but I only checked the one in the fuse box. But you say there should be one on the back of the radio as well? I will try that next, thanks again.
Old Oct 6, 2008 | 11:03 AM
texans's Avatar
texans
no prob. Yeah there should be one on the back. what truck do you have? Is it a factory HU, or aftermarket? If aftermarket, which one is it?
Old Oct 6, 2008 | 12:20 PM
rg4's Avatar
rg4
Sorry, should have specified before. It is a '99 ranger with a factory radio.
Old Oct 6, 2008 | 01:03 PM
Franklin2's Avatar
Franklin2
If it's the factory radio, it will not have a fuse behind it. I would check all the fuses, and if they all look good, I believe the radio is fried. Make sure to check all the fuses, since you may have a seperate amplfier somewhere else.
Old Oct 6, 2008 | 01:34 PM
texans's Avatar
texans
the quikest way I have found to check fuses. Is too use a multimeter and check for continuity between the two ends of the fuse. If you use the small metal parts on the back of the fuse you dont have to pull them out. I normaly just check all fuses at this time. You never know which ones might be tied to the radio.
Old Oct 6, 2008 | 02:00 PM
fmc400's Avatar
fmc400
MSEE
Not trying to scare off newcomers, but your post begs the question:
1. Why were you trying to get your truck started while you were drunk? I certainly hope you didn't drive it after you started it.
2. Beside from the obvious issues with driving, working with jumper cables and high capacity batteries while intoxicated is a good way to get killed.
Anyway, welcome to the site, and I agree with everyone else - check the fuse, and if it's no dice, then I'd say you're lucky that you only fried the radio and not something else like the rectifier in the alternator.
Old Oct 6, 2008 | 08:28 PM
rg4's Avatar
rg4
So if I were to just buy a new radio it should work?
Old Oct 6, 2008 | 08:29 PM
rg4's Avatar
rg4
Had a couple of vehicles turned off with the lights on a game of corn-hole. no driving involved.
Old Oct 6, 2008 | 09:39 PM
texans's Avatar
texans
If the radio is fried then yes just buy a new one. It should work. Anouther thing that I didnt think about earlier is to check and see if you are getting power to the radio. If you have power at the connection. Then I would deffently say get a new radio should do the trick.
Old Oct 6, 2008 | 09:45 PM
rg4's Avatar
rg4
cool, thanks. i've had a new one for a while but have put off the hassle of installing it. guess i have a good reason to put it in now. again, thanks for the tips everyone.
off the subject...so far i really like what i'm seeing after browsing through the boards here. i'm looking forward to some good posting here as i am getting close to buying a new ford truck here in the future.
Old Oct 6, 2008 | 09:57 PM
texans's Avatar
texans
your welcome. good thing you have a new one laying around. I think if you stick around you will end up like most of us and addicted to this site. My wife gets so mad at me sometimes, cause I am always logging on to see what going on in ford land
edit...Let me know if you need any help with the install
Old Oct 7, 2008 | 04:49 AM
shorebird's Avatar
shorebird
Watch out for the FTW syndrome. Red eyes, yawning and loss of time awareness.If you were to look at my posts you will find that they occure at almost anytime of the day or night. FTW does not cure insomnia.
