i have an 86 bronco with 35 on it looks awesome and is fun all i did was a body lift 4'' it cost like $300 canadian + 1200 for the tires so get r done lol
yep, 33 will fit fine without any lift at all. but please tell me you're going w/a suspension lift. Friends dont friends buy body lifts. (at least not bigger than 1.5")
its a 1992 v8 what ever the stock gears are is what it has .I am thinking of a 4 or 6 inch lift but no body lift for sure.The lift kit im thinking is rough country if i remember right.but the lift is for show mostly i spend most my time driving on the freeway.
Just remember with larger tire you need to reprogram your speedo (it'll be of about 12-13% w/35s) and look in to changing gears. 35's on stock gears will kill you mpgs and power.
I run 35s with a 6inch lift. The front tires rub on the lower corners of the front fenders when hitting hard bumps. No damage just a little black on the fenders.
