Are 302 + 351W distributors the same?
Ford distributors
Looking at the distributors it would appear that the basic castings are the same, as they actually do have the same height and general configuration. But as Mark's post implied, the diameter of the part which goes into the block is different, 1-1/2" on the 221-302, and 1-9/16" on the 351W. But hey-that's Ford.
Also, the shaft diameter on which the gear mounts is larger on the 351, as is the hex recess for the oil pump drive.
Not free but they are on sale:
If you decide to get a new distributor, consider our custom curved Duraspark Distributor built with our new Full Length Oil Impregnated Bronze Bushing. The full length bushing improves timing stability and spark scatter. If stock appearance is not an issue, take a look at our one piece D.U.I. Distributor. Whether you choose the Duraspark or the D.U.I., we curve each on a distributor machine based on your engine combination. Please see them at:
http://www.performancedistributors.com/forddistributors.htm
Also, there is now an excellent installation article on the D.U.I. Distributor on the Ford-Trucks.com site at:
https://www.ford-trucks.com/article/idx/0/358/article/DUI_Ignition_Installation_In_A_Ford_351W_V8.html
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
FTE Sponsor
Rogue_Wulff
36
02-22-2021 10:32 PM
Lagniappe
09-26-2015 12:42 PM
chipper
12-30-2003 08:19 AM
