Odd start up problem
Old Oct 5, 2008 | 05:03 PM
powerstrokebill's Avatar
powerstrokebill
Hello,
Yesterday the truck started up ok and I pulled it into the drive from the garage. ran ok, came back to start up a few minutes later and it went wild.
here are some of the issues besides not starting: clicking relay under the dash, rpm gauge went up 1000 and bounced wildly, speed gauge moved, strange buzzer noise.
checked and charged batteries, checked some fuses under the dash, batteries read 100% charge but after I tried to start the batteries read lower then quickly charged back up on 2 amp cycle charge.
i did move the truck from my level garage to my inclined driveway, and I was getting low on fuel the night before. should I check for no fuel issues?
i haven't had the CPS changed.
Any ideas?
Thanks, -Bill
Old Oct 5, 2008 | 05:28 PM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
How old are the batteries? These trucks require a lot juice to run correctly and bad batteries can cause all sorts of strange symptoms.
Oh, by the way, welcome to FTE. Stick around, this is a great place to learn about your truck.
One of the gurus should chime in soon with more ideas.
Old Oct 5, 2008 | 05:32 PM
clux's Avatar
clux
TO is right, check the battery voltage and clean the terminals.
Old Oct 5, 2008 | 05:49 PM
UP_There's Avatar
UP_There
do you by chance have a cracked windshield? A small leak onto the PCM can do some really weird things with these trucks. A CPS issue could be the problem, but I don't recall ever getting any buzzer noises, just random stalling issues.
Old Oct 5, 2008 | 05:58 PM
GEugeneS's Avatar
GEugeneS
I'd bet the battery terminals are corroded.
Old Oct 5, 2008 | 07:02 PM
4inchlovin's Avatar
4inchlovin
Sounds like a loose or dirty cable... Or even a bad ground SOMEWHERE... Do you have a chip/tuner? Either way good luck and welcome to FTE!!! Let us know what you find!
Old Oct 5, 2008 | 07:23 PM
STROKIN'IT7.3's Avatar
STROKIN'IT7.3
Batteries or cables. Check BOTH ends of the cables, not just on the batteries themselves. Let us know what you find and welcome!
