What is this??
Old Oct 5, 2008 | 10:41 AM
jmonintwo's Avatar
jmonintwo
What is this??
I've got a 95 I6. I think the guy I bought it from said he made that tan colored "spacer" in between the intake manifold and the air intake side. He said he did it to get better MPG. I don't know if it does any good. My MPG on the highway at 65mph with M5OD trans is around 14....ouch. DO you think this spacer helps any??
Old Oct 5, 2008 | 10:50 AM
subford's Avatar
subford
No, why would it, you are only moving the air control (throttle) and you would get the same amount of air control.
Old Oct 5, 2008 | 10:59 AM
themoparkid's Avatar
themoparkid
looks like he made that spacer out of wood
jmonintwo's Avatar
jmonintwo
Thanks....kin-of what I thought. I wonder if it's worth the trouble to take it out...or should I just leave it there?
Old Oct 5, 2008 | 11:12 AM
quicklook2's Avatar
quicklook2
that is one of the craziest things i have seen for awhile on fte.
thanks for the laugh.
i would take it off, it is doing no good.
Old Oct 5, 2008 | 11:40 AM
preppypyro's Avatar
preppypyro
Although its probably not causing any harm, i would still take it out.
Old Oct 6, 2008 | 05:23 PM
TexasGuy001's Avatar
TexasGuy001
Throttle body spacers are junk! Toss it in the trash.
Old Oct 6, 2008 | 05:33 PM
andym's Avatar
andym
Wow, a wooden throttle body spacer. That's awesome.
Old Oct 6, 2008 | 06:58 PM
tbear's Avatar
tbear
Looks almost like a fabric. Reminds me of Bakelite
Old Oct 6, 2008 | 07:06 PM
EPNCSU2006's Avatar
EPNCSU2006
It's probably made from phenolic, not wood. I doubt that it is hurting anything, but I don't know that it helps anything either. It changes the overall plenum volume, but probably not appreciably.
Old Oct 6, 2008 | 07:07 PM
85e150's Avatar
85e150
Your mpg is a bit low unless you are carrying 5000 lbs at 65 through hill country. Perhaps a systematic check of the efi, airflow meter, ignition, vacuum, compression would be in order to see if something simple is costing you 3 to 6 mpg. The spacer might be contributing to a vacuum leak--easy enough to tell, just spray wd40 or carb cleaner around it at idle. Any change in idle speed/quality points to a leak. Ditto the intake manifold.
Good luck.
Old Oct 6, 2008 | 09:49 PM
tbear's Avatar
tbear
phenolic and Bakelite are one and the same....just the original brand name. FYI The WIKI link shows a distributor rotor made of bakelite. Bakelite - Wikipedia, the free encyclopedia
Old Oct 6, 2008 | 11:07 PM
Surge08's Avatar
Surge08
Never seen a wooden one, seen an AirRaid be for but not wood
Fabbed5.0
New Member Introductions
Sep 30, 2013 12:53 AM
phil6608
Delaware Chapter
43
Aug 1, 2008 07:33 PM
jmonintwo
Jun 22, 2008 08:46 PM
phil6608
Delaware Chapter
353
Jun 2, 2008 03:45 PM
phil6608
Maryland Chapter
413
May 17, 2008 10:01 PM
