Fast - rebuilding a very low mileage PnP find to replace my worn out 360.
bore .030 over, new 9.5:1 CR flat top pistons
balance rotating assembly and new bearings
rebuild heads with hardened seats and a mild porting & polishing.
4bbl and headers.
Nothing to special, but it'll be strong and get reasonable gas mileage and last till my 3 yo is ready to drive. That's if we'll be allowed to drive gas powered vehicles in 13 years
Neverenough - I'll have in the neighborhood of 340 hp and 350 ft-lbs torque. I think that's more than I need. If I hadn't started down this path about a year ago, I'd go with a 4.9l with an AOD and some mild improvements. Better mileage and approp. amount of HP. I don't do any towing and very little hauling. A V8 is over kill for me.
But I'll just have to live with the 390 I guess
I get a tankful avg of 12mpg with my 300. It would be better if I had either an overdrive, higher rear gears, or higher compression, or all of the above. I'd guess I'm at around 200hp & 300 for tq. Good enuf for a daily driver.
I get a tankful avg of 12mpg with my 300. It would be better if I had either an overdrive, higher rear gears, or higher compression, or all of the above..
Sounds like everybody is busy. I've been swamped at work. There is some good news: Gas is dropping$$. Also, I am watching the stock market. I am tempted to take some money out of savings and buy 500 shares of FORD stock. At $2.30 a share, it's a steal. Hope to see some of you at Vintage Ford's show on the 24th. Jag
im here too ive just been busy with hunting season. just got back from elk hunting in colorado yesterday but other than that ive just been piled under schoolwork.
