fuel pump? max fluid temp.??
Old Oct 4, 2008 | 09:13 AM
kent's f-350's Avatar
kent's f-350
helo all, i was wanting to put a fuel filter/heater be for the pump, the fuel heater will heat it up to 160-180* and did not know if that would be to hot for the fuel pump?
i am running wvo and need to heat this stuff peff. be for the pump so it won't be so thick, but don't want to overheat the pump.
Old Oct 4, 2008 | 06:43 PM
firemediceric's Avatar
firemediceric
I don't know the answer, but if you contact Jason at Dino Fuel Alternatives, the sponser of the Alt Fuels section down below, or Chris at Frybrid, I'll bet one of them will know the answer.
I guess that's an upside to living in Florida. I don't have to worry quite so much about heat.
