1966 4x4 Pulling Truck
some questions I need some opinions on for my '66 F250 4x4
street stock puller project ...
First concern -- is the stock Dana 44-6F front end up
to the challenge ?
The gear ratio is 4.56 , tranny is truck 4 spd .
Motor choices are , from least likely to most likely ...
351W w/Cleveland heads ( too much work for what it is worth )
351CJ ( gonna restore this one for my " collection " to be preserved .
FE ( 352 , 390 , 410 ) ... ( only FE on the farm ,
not many spare parts , but I have one in the truck ... )
400C ( I have a good cast Cleveland Cast block , lots of parts )
460 ( slighty warmed over ... still streetable ,
plenty of parts - just a big Cleveland :-) ( can ya tell I'm
kinda hooked on Clevelands ? :-) ).
Most people think the 44F will be strong enough for a starter
as long as I keep the wheels on the ground ( unlike my bogging
friends
) ....Can a Dana 60 front axle be adapted to the '65/'66
steering without a big hassle ?
If the 44 is not a good start and the 60 front does not adapt
to the '66 steering , I could set my '66 2wd body parts on a
'78-'79 F350 chasis ... a real possibility ...
I have a '66 F250 4wd in good shape and 1 for parts .
I also have nice rust free 2wd '66 parts , so I can go
either way . I cann't afford both ways
.Using the '66 F250 with stock D44 in front would be the
easiest , and also the cheapest to start with
( a real concern for a married man w/ 3 kids ).
Will limited slip units be needed ?
Do I need to change the chassis height from stock '66 ?
My first thought is that the front drive shaft has too
much angle.
I can lower the rear by removing the stock lift blocks .
Lowering the front could be a problem . I'm thinking of using
90s style reverse bend springs
( not sure of the official term ) .
I have a 66 2wd 8' box I'd like to use.I'll need to move the
rear end back 9" to line the axle with the box wheelwell.
This will lessen the angle to the rear a tad .
This could allow me to move the transfer case back ,
thus reducing the front angle a bit although Moving the
transfer case may be more work than it is worth if I can
lower the front using the newer leaf springs .
I was told to update to Spicer HD joints w/o zerks for strength.
Thanks,done rambling for a moment.
I have too many parts and need to decide if I'm going with
an original '66 4wd or a '66 2wd body set on a '78/'79 F350 .
Thank You
dave Prasse
Freeport , Il
'66 Beige Beast 4x4
RubberDuck
RubberDuck
Either truck will look the same , externally .
Guess I 'm looking for opinions on whether or not the Dana44
on the front of the '66 F250 will be strong enough for
pulling a sled with a built , not wild , 460 .
If it is , at least to get started , the'66 gets the nod .
If I start with the '66 & Dana 44 , Is there an easy way to upgrade to a Dana 60 ? How does the steering hook up ?
If the upgrade is tricky , then the 78/79 chasis gets the nod with my '66 2wd body parts .
Headers through my hood ?
Not legal in street stock .
I have a set for a Boss429 hhmmmm ...
wonder if the wife would allow 2 4wds
( but Dear , one is Street Stock and one is Super Stock )
dP
RubberDuck
