Vin # help
Oct 2, 2008 | 12:44 PM
Vin # help
Here is the vin # if anyone can help. I'm going to try to look it up to.
F10HLT18979 Here are somemore #'s 133 U F105 0 4 G 17J
Thanks
Scott B.
Oct 2, 2008 | 02:19 PM
Quote:
Originally Posted by
restoringmy46
F10HLT18979 Here are somemore #'s 133 U F105 O 4 G 17J
Scott B.
F10 = F100 2WD
H = 390 2V
L = Michigan Truck Assembly Plant
T18979 = 1974
133 = 133" Wheelbase
U = Medium Lime Metallic
F105 = F100 2WD / 5100 lbs. GVWR
O4: O = Medium Green Vinyl & Medium Green Cloth / 4 = Bench Seat
G = C6 Cruise-O-Matic
17J: 17 = Ford 9" Rear End / 3.25-1 / non Limited Slip / 3300 lb. Rear Axle Capacity // J = Power Steering
Oct 2, 2008 | 02:20 PM
1974 F100 2wd 390 2bbl auto probably c4 Michigan truck 3.25 3300lb rear axle
I think the j on 17 is power steering
Oct 2, 2008 | 02:23 PM
slaid
No C4 transmissions were used with FE (352/360/390) engines.
1965/67 F100/350 352: MX Cruise-O-Matic / 1968/76 F100/350 360/390 = C6 Cruise-O-Matic.
Oct 2, 2008 | 02:31 PM
The G on the vin decoder just says auto and probably c6. Both of my 78 f150 have c4s but they are behind 302 eng. Thats good to know.
Oct 2, 2008 | 02:44 PM
slaid
Ford confusion: Every Warranty Plate has a
G for the A/T code from 1965 thru 1978, regardless of the A/T type.
1979:
G = C4 /
K = C6.
Ford assumed parts & service personnel would know which
G was used with what engine.
1978 was the first year that Ford offered a C6 on an F100/150 w/a 302 engine.
More 1979 F100/150's w/302's have C6's than C4's.
