engine growl
Old Oct 2, 2008 | 08:51 AM
mybigredford's Avatar
mybigredford
engine growl
hey guys for a while now i have niticed that i have or seems like a more of a deeper engine growl in the cab and i cant seem to figure it out, everything seems good under the hood, could this be my imagination? also seems like it is on the divers side more.
Old Oct 2, 2008 | 08:54 AM
just another truck's Avatar
just another truck
Is it non stop? Does it only happen when your defrost/A/C is on? When was your last Fuel filter change? Have you looked for soot on the up pipes? Last, but not least, can you remove your serpintine belt and check the idler pully? Most importantly, Good Luck!!! I hope this helps.
Old Oct 2, 2008 | 09:02 AM
rmilchman's Avatar
rmilchman
Exhaust leak?
Old Oct 2, 2008 | 09:16 AM
F350-6's Avatar
F350-6
Is it just barely noticeable? You might consider changing your air filter. Mine gets a slightly different sound when the filter is dirty.
