Offroad & 4x4
Gear ratio ?????
Old Sep 4, 2001 | 01:58 PM
AZ4x4f150's Avatar
AZ4x4f150
Gear ratio ?????
I have a 82 F150 4x4 5.0L with 33x12.50x15 tires and 3:0 gears front and rear with a BW-1345 transfer case and a 3" lift I want to put a 2" body lift in and and run 35x12.50x15 tires. with the current setup it actually doesn't do to bad off-road everything i point the truck at it has overcome with out a problem. But if I put the 2' body lift in and the 35's I am worried about the current gear ratio's and what will happen when I go off-road with the new set-up. Another question I have is am I wrong thinking my truck came with a Ford 9" rearend or did it come with an 8.8" rear end
Old Sep 6, 2001 | 09:21 AM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
Gear ratio ?????
AZ, try these links to get an idea how changes in tire size affect performance. It looks like 35" tires would be the same as reducing the axle ratios to 2.83.
https://www.ford-trucks.com/articles/gearcalc.html
[link:www.4lo.com|Tire size change calculator]
Old Sep 7, 2001 | 07:24 AM
72f100's Avatar
72f100
Gear ratio ?????
W/ an 82 I believe you still have a 9". The easiest way to tell is to look at the back of the axle. An 8.8" will have a removable cover where a 9" will not. W/ 35's and 3.0 gears your truck will be a dog on the street. Throwing it in low range will help drastically off road and you will probably be alright, as long as you aren't doing some major rock crawling or other really slow speed stuff. Seriously, w/ 35's I'd really consider swaping to at least a 3.50 gear; a 3.70 will make life alot easier on the street. I have a 3.50 gear now w/ 35's and a fairly stout 390. My truck feels strong on the street but I can tell it's fighting the gears. I'd go 3.70's if I were you; 4.10's if you have an overdrive.
"like a rock" on the sides of roads everywhere.
72 F-100 4x4. fresh 390 4bbl, NP435 tranny, spooled rear, 2"skyjacker springs front, 2" custom shackle flip rear, "mild" fender trim, 35x15.50 TSL/SX tires.
Old Oct 1, 2001 | 11:25 PM
hoss's Avatar
hoss
Gear ratio ?????
Go with 4.10's. Bigger or smaller they're a good median in gear ratios. With 35's, you won't be happy with 3.55's; and 4.56's will sacrifice on-road speed. You've got a 9", but you might only have 28 spline axles.
'96 F150
Old Oct 2, 2001 | 07:25 AM
82F100SWB's Avatar
82F100SWB
Gear ratio ?????
An 82 should have a 31 spline 9", mine does....
With 35's, you'll want something in the low threes, maybe 3.73, or maybe even 4.10's. My 3.55's and 31x10.50's are a near perfect match for my 300.
Evan MacDonald
82 F100 FlareSide 4wd
HD 300-6 9.5:1 CR
Clifford 270H cam
Hedman Hedder
SBC valved 66 240 head
Headlight Relays - Delanty Style
NP435(6.69 low)
NP 205
3.55 Geared ARB'd 9" & Trac-Locked TTB
31x10.50/15 Cooper Discoverer LT's
Old Oct 3, 2001 | 09:25 AM
lt1yj's Avatar
lt1yj
Gear ratio ?????
Justin Braun
Mar 26, 2017 11:26 AM
voadrummer
3.8 & 4.2L V6
May 10, 2015 05:21 PM
MerCrew66
Jun 8, 2003 11:54 PM
BigBoyStone
Offroad & 4x4
Aug 31, 2002 03:57 PM
traildawg
Offroad & 4x4
Feb 12, 2001 10:03 PM
