transmission drive gear
Old Oct 1, 2008 | 08:24 PM
66f-100's Avatar
66f-100
I am swapping out my dying COM for a C6 and mating it to my 352. The C6 is a '67 model out of a passenger car. I have the truck arm for the shifter linkage. I am trying to figure out which speedometer gear to use. I have a program to calculate the driven gear but the question I have relates to the drive gear. I thought small block transmissions typically had a 7 tooth drive gear and big block transmissions typically had a 6 tooth drive gear. At least, this is what I am used to with Mustangs. Anyway, while the trans was being rebuilt today I counted the teeth and came up with 8? Is that possible, I was expecting 6 or 7, not 8. Any thoughts would be appreciated.
Mark
Old Oct 2, 2008 | 01:59 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 66f-100
I am swapping out my dying COM for a C6 and mating it to my 352. The C6 is a '67 model out of a passenger car. I have the truck arm for the shifter linkage. I am trying to figure out which speedometer gear to use. I have a program to calculate the driven gear but the question I have relates to the drive gear. I thought small block transmissions typically had a 7 tooth drive gear and big block transmissions typically had a 6 tooth drive gear. At least, this is what I am used to with Mustangs. Anyway, while the trans was being rebuilt today I counted the teeth and came up with 8? Is that possible,YES. I was expecting 6 or 7, not 8. Any thoughts would be (appreciated. Mark
The size of the engine has nothing to do with what teeth are on the drive and driven gears.
For example, C8OZ-17285-B is a nylon 8 tooth drive gear (brown in color) and was used on some cars w/289's and 390's. The teeth run this-away: ///
C5OZ-17285-B is a steel 8 tooth drive gear and was used on some cars (including Mustangs) with 289's. The teeth run this-away: \\\
It all depends on the application and the following: Tire Size / Rear Axle Ratio / Transmission Type.
You counted the number of teeth from the '67 passenger car's C6 (output shaft) drive gear, but did you take a close up look at that gear?
You may be in for a surprise, because there is no drive gear on the output shaft that is removable.
On C6's transmissions of this vintage, the drive gear is made as part of the output shaft.
Info source: 1965/72 Ford Passenger Car Parts Catalog / Speedo Drive & Driven Gear Application and ID Charts / Section 172 & Sections 172.65 thru 172.72.
btw: C6's / 360/390's were not installed in F100/350's till 1968.
Old Oct 2, 2008 | 06:18 AM
66f-100's Avatar
66f-100
Yes, the gear was part of the output shaft. So I guess I counted correctly then? Thanks, Bill.
1972RedNeck
Apr 20, 2016 03:21 PM
Superduty.pride
1978 - 1996 Big Bronco
Feb 24, 2016 01:35 PM
Randle
Sep 18, 2015 08:23 PM
Rusty_S
19
Jul 10, 2014 07:35 PM
Cougar54
42
Mar 23, 2014 01:41 PM
