Aerostar Ford Aerostar
Taurus vs Aero
Old Oct 1, 2008 | 03:33 PM
Pablo-UA's Avatar
Pablo-UA
Taurus vs Aero
I usually drive aero to countryside, but I leaved aero in bodyshop to repaint front bumper and draw taurus.
today driving taurus I got in stuck in place I used to drive throught in my aero easily. mud was not so deep, but taurus sank in mud aka stone in water.
But it was not all. I asked Zil truck driver to tow my taurus out. But there is no front hitch under bumper. I was so dirty when I finally fasten cabel to engine frame. Zil started towing taurus out but cabel fastener cracked and broken licensie frame frame. Plate fall down. Bent a bit.
Well, I'm finally home.
P/S I will newer drive taurus to countryside againe....
Old Oct 2, 2008 | 11:05 AM
aerocolorado's Avatar
aerocolorado
Not fun going to Elbonia you say?
We had a '92 Taurus, and if memory serves, there was a small eye hook on the front frame, driver side, but it was located close the the frame and would be easy to overlook if the car were sunk in mud. I tried to help a guy with a Neon out of a snowdrift once. The bottom side was all stamped metal. Absolutely nothing to hook onto except those spindly rear suspension linkages. We dug it out instead.
(btw: Elbonia is a fictional place in a popular comic strip over here. Elbonia is a county covered by mud and its inhabitants wade around hip deep.)
Old Oct 2, 2008 | 11:50 AM
Pablo-UA's Avatar
Pablo-UA
Elbonia..... There are some places over here like this....
well, finally clean. Hook was deep in mud. That's why I could not find it. Newer cars have removable hooks (usually it is in the same place with jack)
Old Oct 2, 2008 | 02:06 PM
aerocolorado
Hey! That looks like our old Taurus. I always wondered where it went. Is that snow on the mountain in the background?
Old Oct 2, 2008 | 03:18 PM
Pablo-UA's Avatar
Pablo-UA
My os from Iowa.
Well, today I got forst Taurus trouble. No heat. Toched both the heter core hoses under hood. Both are hot. Ouh!!!!
I do not really know how to access temp. door.... is it possible w/o dash removing?
Old Oct 2, 2008 | 03:44 PM
aerocolorado
I've read that its possible - difficult, but possible - without taking the entire dash apart. That said, I have not tried it. As I recall, there was some cutting of a lower panel to gain access to the blend door assembly. Good luck!
Old Oct 2, 2008 | 03:53 PM
Pablo-UA's Avatar
Pablo-UA
is it on pass. side ore in center of car?
Old Oct 2, 2008 | 03:55 PM
aerocolorado
I believe it is toward the center area as that's where the heater core is located. I would expect the same arrangement as the Aerostar.
Old Oct 2, 2008 | 04:00 PM
Pablo-UA's Avatar
Pablo-UA
i gonna try tommorow.... Thnx!
Old Oct 3, 2008 | 09:34 AM
Pablo-UA's Avatar
Pablo-UA
pulled out heater controll and checked voltage on temp. regulator. It variates from 0 to 11.9V depending on positiion. But temp door intermediatly stops. Ouh!!!
well. a pic of truck towed me out from Elbonia
Old Oct 3, 2008 | 09:39 AM
Pablo-UA's Avatar
Pablo-UA
Old Oct 3, 2008 | 10:20 AM
aerocolorado
Yeah, you wouldn't want to go into Elbonia without a Zil Muck Monster. Nice picture.
I think your blend door actuator is broken. Very common on lots of Fords of that vintage.
I had the same problem with our Ranger and was able to fix it with the "Nail" cure. Here's a link to an excellent posting from the Ranger forum with good illustrations of what you are in for: https://www.ford-trucks.com/forums/7...lend-door.html
Old Oct 3, 2008 | 02:20 PM
Pablo-UA's Avatar
Pablo-UA
seems to me it stucks, but how to access there? I love aero, I can pull glove box out and take heater apart....
Old Oct 3, 2008 | 03:20 PM
Pablo-UA's Avatar
Pablo-UA
Ouh, exuse me. I identified truck wrong. It is old KRAZ. This is truck of my friend's company. They have really strange business, they dig out old gas/oil/water tubes. There are many tubes that were put in ground and were used, but later were not in use. Owner call them to dig out bad/old tobes for reuse ore utilisation. Really unusual business. They have Volvo semitracktors and I use to repare electronics in them...
RojoStar
Aerostar
34
Jan 15, 2020 03:42 PM
Pablo-UA
Aerostar
17
Jan 25, 2009 02:54 AM
nascar88ford
General Automotive Discussion
Feb 26, 2006 07:56 PM
Saurian
Aug 23, 2005 10:40 AM
NH-Hottie
19
Mar 26, 2004 06:04 PM
