85 302 issues, need help.
Old Oct 1, 2008 | 09:25 AM
CDF302v8's Avatar
CDF302v8
Question 85 302 issues, need help.
Can anyone help me on this problem?
My 85 f150 with a 302 efi will start right up when cold, but when it is warm (after driving it for awhile), it does not like to start back up. It usually just keeps cranking for a long while. Is it the coil?
Old Oct 1, 2008 | 09:40 AM
Conanski's Avatar
Conanski
Could be a lot of things. Do you hear the fuel pumps cycle on the warm start? If it does it would be a good idea to check the fuel presure at the rail, your truck has both an in-tank low pressure pump and and external high pressure pump, if either of these are not startiing up right away you won't get full pressure and the motor won't light very quickly.
Old Oct 1, 2008 | 10:02 AM
vwkess's Avatar
vwkess
On the multi-port EFI, I have seen heat soaked idle air control valves stick and cause this. If it is starting fine cold, the pressure regulator is probably OK and holding pressure. Like Conanski says it would be a good idea to check fuel pressure and make sure there is enough residual pressure there when warm before starting.
Old Oct 1, 2008 | 11:01 AM
CDF302v8's Avatar
CDF302v8
i havent tried to hear the fuel pump yet, Well i havent just held the key until it starts...i gave it VERY little gas and it would fire. I have heard that it may be the coil, or plugs?
Old Oct 1, 2008 | 11:02 AM
CDF302v8's Avatar
CDF302v8
Ok, thanks!
I will check it when i get it out in the spring, unless i figure out it is something else.
Old Oct 1, 2008 | 11:15 AM
vwkess's Avatar
vwkess
BTW, I highly doubt it is the coil or plugs if it runs fine after it starts. With a bad coil or plugs the engine breaks up (misses) pretty good when you rev it or put it under load.
Old Oct 1, 2008 | 08:55 PM
CDF302v8's Avatar
CDF302v8
Well i do need pugs...but i just heard that it may be the coil. So, if i have little fuel pressure, what? will i need a new pump?
Old Oct 2, 2008 | 10:22 AM
vwkess's Avatar
vwkess
Maybe, or could be clogged fuel filter. But realistically if it runs fine that is probably all OK. From my experience, your starting problem is usually either a failing coolant temperature sensor or sticky IAC valve.
Old Oct 2, 2008 | 11:30 AM
subford's Avatar
subford
What he said but you also might try holding the throttle on the floor when it is warm and see if it starts OK.
Also check the coils plug I have seen these plugs give a lot of problems.
Old Oct 2, 2008 | 02:59 PM
CDF302v8's Avatar
CDF302v8
If i give it a little bit of gas, it will fire, but will run like crap until i get it movin.
Old Oct 2, 2008 | 03:01 PM
CDF302v8's Avatar
CDF302v8
I will have to take a look at those soon.
Old Oct 2, 2008 | 03:12 PM
subford's Avatar
subford
I think you need to read your codes and see what is going on. Post the codes back and we should able to hel some more.
If you do not know how to read the codes click on this URL below.
Ford Computer Codes
