AC Draining - Where?
Old Oct 1, 2008 | 07:24 AM
enggass's Avatar
enggass
OK. If my AC were draining properly, where would I see the drain puddle?
I just ran the AC at 60 for about 10 minutes, and nothing!???
Thanks,
Steve
Old Oct 1, 2008 | 10:51 AM
98greensi's Avatar
98greensi
you should see a puddle under the truck on the ground. the drain drains threw the firewall and comes out near the middle of the truck but closer to the pass side.
Old Oct 1, 2008 | 11:15 AM
enggass's Avatar
enggass
Others have said that the drain is near the right front tire???
Anyone?
Old Oct 1, 2008 | 01:36 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
The drain should be on the passenger side of the firewall a little ways below the heater/ac housing level. It is a rubber tube. it should make a puddle of clean water under the vehicle near the rear of the right front tire, just to the inside of the tire. the puddle will only form after the vehicle has been shut off for a few minutes. Dan.
Old Oct 1, 2008 | 09:23 PM
SteelHorse08's Avatar
SteelHorse08
98Green is correct the other guy down below is misguiding ya, the a/c drains while driving as well and at idle, not just after you shut off the engine.
Steve Aerostar
Aerostar
Sep 9, 2014 10:30 PM
raye321
Sep 4, 2014 11:16 AM
blowhole
Jul 10, 2010 07:35 PM
blowhole
Jul 9, 2010 07:34 PM
