Sponsored by: Auxito
Egr Mess.....
Old Sep 30, 2008 | 08:54 PM
chillin2nite2's Avatar
chillin2nite2
Egr Mess.....
hey i have a 2001 f150 4x4 5.4L
i keep getting the same two codes code P0401 Insufficient EGR Flow and P402 "excessive EGR flow. i've had the intaKe off n cleaned all the carbon i've replaces the dfpe and the EGR vac solenoid i've had the egr valve off n check it . i dont know what else to do this has been driveing me nuts for months i hope someone can help me thanks
Old Sep 30, 2008 | 09:43 PM
torkum's Avatar
torkum
Have you checked the wiring and connector to the DPFE? When you say that you checked the EGR did you apply vacuum and it ran rough?
If you a sure you've checked everything, I would talk to a Ford service manager about a reflash. I had a code for a IAT that would not go away and I followed the shop manual to the T and finally took it to the dealer and got them to wave the diagnostic charge of $95 and just do the flash.
Old Oct 2, 2008 | 03:37 PM
morrowtruth's Avatar
morrowtruth
are the egr tube hoses disconnected or leaking? I just went through an ordeal with my egr tube, ended up putting new headers and egr tube, but temporarily, I blocked off the egr and accidentaly left the hoses unhooked, and got the 0401. Id see if those hoses are good.
TXE150
Jan 3, 2015 06:10 PM
daisyq31
Escape & Escape Hybrid
May 8, 2013 10:25 AM
5Rangers
Jul 25, 2011 09:42 PM
confusedranger
1983 - 2012 Ranger & B-Series
Nov 10, 2009 02:57 AM
mmjax25
1997 - 2003 F150
Apr 21, 2008 07:17 AM
