Heater problem
1997 F250 V8
I have tried everything, new heater core, tore apart the dash and all valves are working ok(heating and cooling vents) great air flow, when you reach up in the box it is very warm. You get more heat when its on vent than when on heater. Any ideas?
don't know if this will help, but my truck (2003 f250) won't blow hot air either. Everything seems to be working as your describing. I'm leaning toward the door blend actuator that's gone out, might be the same for you. just a thought
