Brake problems
Old Sep 29, 2008 | 11:11 PM
Farmerg58's Avatar
Farmerg58
Brake problems
I have a 1990 Ford F350 XLT Lariet 2wd, my brakes keep locking up, I have reaplaced the master cylinder, rear wheel cylinders, wheel hardware, brake shoes and rubber brake line at rear of vehicle, one wheel keeps locking up and I don't know what else to do. Please help me if you have an answer.
Old Sep 30, 2008 | 03:59 AM
ymeski56's Avatar
ymeski56
Der Postmeister
And which wheel might that be? the rear drum brake units each have a self adjust mechanism (top rear part of brake)that allows adjustment by applying the parking break while driving in reverse. I don't know what effect one side being set at a more advanced setting compared to the other would result in. I think failure to compleatly remove air in system would do it. Was this the reason for the brake work or the result of? Also what have the brake & ABS warning lights been doing all this? There is a terminal under dash/driver side that provides ABS sys error codes via similar paperclip method used for ECC code retrievals.
Old Oct 1, 2008 | 10:17 PM
hladun's Avatar
hladun
Any chance your parking brake cable is stuck?
Old Oct 1, 2008 | 10:33 PM
quaddriver's Avatar
quaddriver
and if that fails - turn the drums
jmauldin
Jul 17, 2012 02:15 PM
bkbauer1955
Feb 2, 2012 04:46 PM
89ford73
Apr 12, 2011 08:56 PM
DansBBF250
20
Jun 30, 2010 08:45 PM
f350lord
16
Oct 12, 2009 08:29 AM
