electrical problem!
Old Sep 29, 2008 | 03:17 PM
shortys07's Avatar
shortys07
electrical problem!
Truck- 2000 7.3 psd auto.
I go to start my truck this morning turn it to the on position to wait for the glow plugs and fuel pump prime and it just starts making this clicking noise, located the noise and it was the top left relay in the fuse box located inside the cab.( what relay is that? the previous owner lost the fuse box cover)
Odd thing was i didnt get any power at all to anything, no stereo, no windows etc just that clicking noise of the relay.. So i proceded the check all fuses- checked out fine. removed all relays to check for corrosion and they all checked out fine. checked both battiers 12.5 volts also checked connections
I disconected both battiers for 10min hook them back up and try to start it, i get full power and i hear the fuel pump prime and glow plug relay. Go to start it and it starts making the relay click again.
I was thinking the relay? or possibly ingnition switch?
Wondering if any one has had this problem? i need some thoughts
Thanks again guys and gals
Old Sep 29, 2008 | 04:19 PM
Smokin''s Avatar
Smokin'
Smokin
That clicky clicky noise is a dead giveaway that you have a huge power drain. I'm not sure where the noise originates from, but it's PSD language for "check my batteries"
Recheck your cables/connections/terminals and unhook each battery and load test them, I'd bet you have a dead battery. They are wired in paralell so if you didn't unhook them to test them you are getting false readings.
Old Sep 29, 2008 | 04:32 PM
Ponyboychris's Avatar
Ponyboychris
What Lisa said^^^ I bought my truck with chattering relays and it was dying batteries that caused the problem.
Old Sep 29, 2008 | 04:37 PM
megawatt00's Avatar
megawatt00
Lisa and Chris hit it right on the head. One bad battery can cause the other to go down, especially under load. A good way to verify this is to take a DMM and test the voltage then when trying to crank you'll see the voltage drop. While your at it check all the cables including the grounds, both ends.
Old Sep 29, 2008 | 05:02 PM
shortys07's Avatar
shortys07
I did un hook the grounds on both and checked voltage. both read around 12.5.
I can throw them on the charger but its kind of weird that it would just die over night. I just drove the truck last night.
One thing i did notice is that when i hook up the passenger side bat ground the hot connect is sizzling?
Old Sep 29, 2008 | 05:05 PM
megawatt00's Avatar
megawatt00
Something is loose or shorting out big time. Trace that wire back and see where it goes.
Old Sep 29, 2008 | 05:10 PM
shortys07's Avatar
shortys07
Alright will do.
Old Sep 29, 2008 | 05:11 PM
shortys07's Avatar
shortys07
can anyone tell me what that relay is though that it chattering?
top left relay in the fuse box located in the cab driver side. skinny 5 prong.
Old Sep 29, 2008 | 05:24 PM
megawatt00's Avatar
megawatt00
Relay 1 is your turn / hazard signals.
http://www.motorcraftservice.com/pub.../00f23og3e.pdf
See pages 149, 150
Old Sep 30, 2008 | 07:27 PM
shortys07's Avatar
shortys07
problem solved, ground wasnt so tight and there was an oily gunk all inside the main positive cable. thanks for all the trouble shooting help!
Old Sep 30, 2008 | 07:32 PM
megawatt00's Avatar
megawatt00
Glad that you got it fixed.
Old Sep 30, 2008 | 08:30 PM
Ponyboychris
Good deal, Glad you found it.
