Master cylinder
Old Sep 29, 2008 | 02:46 PM
Blackwaterforge's Avatar
Blackwaterforge
Master cylinder
Pulled front end from 73 f250 HD,including master cylinder. Truck has dual piston calipers. Installing in 66 F250 Camper Special. Dose master cylinder have residual pressure valves? Rear metering valve? Donor truck has no proportioning valve. Is one necessary? What years will fit? are valves for F100/150's different from F250/350's?
Thank You!
I have a proportioning valve from a 75 f100
# D5TA 2B524-FB. Would this be the correct valve?
Old Sep 29, 2008 | 03:36 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Thank You!
Where did you look for the (Brake Differential) proportioning valve on the donor truck?
With dual master cylinders: All 1967 and later cars & trucks have one.
On most trucks, it's located on the outside of the frame rail behind the left front tire.
On some trucks, it's just below the master cylinder next to the steering gearbox.
There's more than one, it depends on the year, with/without disc brakes, and the GVWR of the vehicle if an F250.
1973/79 F250: I need to know the GVWR, there are two. One is used for a GVWR of 6200 lbs, the other for 6900, 7500 or 8100 lbs.
Ford did not use the term F250 HD till 1985.
Old Sep 29, 2008 | 03:57 PM
Blackwaterforge
The valve from the 73 (8100 lb) was on crossmember between front wheels(is this proportioning)? The one from the 75 f100/150 was located next to MC.
Thank You!
Old Sep 29, 2008 | 04:23 PM
NumberDummy
Thank You!
I don't recall seeing one in that location, but I haven't looked at one of these trucks in over 20 years, so...
Parts catalog shows it in the two locations I posted above. but a parts catalog ain't a shop manual.
The illustrations are mainly for finding part numbers.
The Proportioning Valve is a brass block with 4 brake lines attaching to it.
It also has a 2 pin electrical (plastic) switch that screws on.
This switch is for the low brake fluid warning light on the dash.
C8TZ2B257G .. Brake Differential Proportioning Valve-Use w/Disc Brakes.
Fits: 1968/73 F250 w/6900/7500/8100 GVWR / 1968/73 F350.
I had worse luck with the proportioning valve than I did with those heat shields.
No one has the valve. No Ford dealer, no obsolete dealer...sorry.
Old Sep 29, 2008 | 04:28 PM
Blackwaterforge
Thank You!
Thank You!
I ordered dust shield from Greensales.
One is still in purdy good shape so I am set!
Old Sep 30, 2008 | 08:56 AM
ddavidv's Avatar
ddavidv
One of the donors I pulled my swap parts from had the prop valve on the backside of the engine crossmember. So, that's where I put mine.
